Always looking for a better way to cool forced induction
St. Jude Donor '08
This is kind of a follow up to a prior question. I recently had a Procharger Stage II installed on my car. The two intercoolers sit directly behind the front brake duct openings. If I was to fabricate, using part of the front brake ducts, a duct that goes from these openings and encloses the front of the intercoolers so that all air going into these ducts have nowhere to go, but through the intercoolers, would this help? I am concerned that this “only” route to the intercoolers may deprive them from getting air in certain other conditions. So, what do you think?
Thanks,
Clayton from Las Vegas
Thanks,
St. Jude Donor '08
At the moment, I am not having any cooling problems, but summer here in Vegas has not hit yet. I’m not looking to install any additional fans, just looking for a way to utilize some “free” airflow. So what do you think of the idea of fabricating ducts direct from the front brake ducts (not being used for the brakes) and having them enclose the front of the intercoolers. My concern is will this cause some other problems with them when the car is standing still. I’m sure that when the car is traveling forward, it will get good airflow, as it will be a sort of “ram air” for the intercoolers. Your thoughts?
Thanks,
Thanks,
Thanks,
the fans behind the intercoolers should help when at low speeds but might be restrictive as the speed builds.
thanks CHirs.
Thanks,
Thanks,
Clayton, I have personally run those twins through VERY VERY hot times. 108-110 degrees on some days, in summer. (One car that I have them on runs between 28-32psi of boost)
And have not had any issues with the twins. They cool down almost instantly back to ambient temps once you are out of boost. To the people that are putting the fans on them, I can tell you I have personally tried that, and did back to back comparisons, and it did NOTHING. Other then make my alternator hate me.....because those spal fans draw boat loads of current.
The only time a small Spal fan has come in handy, is when I located the tranny cooler up inside a fender, with absolutely no area for airflow to get to it. Then it can in handy, and it was very justified.
You can either leave them the way they come, and they work very very well. OR, I guess you can try to get more air to them.
BUT REMEMBER THIS...... air in air out. You have to make sure to think about the path the airflow is going to take both in and out. And how it's gonna react in the car.
I know I have personally experimented on other cars with Intercooler placement, and been very very surprised at times. Because of how the airflow changes in front of a car, once it's going 60+ MPH. Weird things happen to the low/ high pressure areas in the front of cars at speed.
Happy Boooooooost'n
EA
Former Vendor
Location: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
Opinions based on my experience with twin IC based systems in Audi 2.7TT motors...
OK guys, here is an idea for all you twin IC guys looking to get better "sort of free" cooling. Water is your friend in this case. What we do and I have done this on my personal S4 and it has taken care of high heat soak issues in highway conditions. I have a intercooler misting system wherein I have a water tank in the trunk which feeds twin spray nozzles from pesticide sprayers firing directly onto the IC via high pressure pump. Water combined with moving air = drop in IAT's. One could go with the SPA Dual Intercooler Gauge to see the temp drops in real time pre/post IC's.
For triggering, I use a foot peddle high beam / low beam switch or could have the SPA gauge trigger the pump when post IC temps hit a certian temp. This is what we do with great results on the Audi's, I developed my design some 5 years ago and fill the tank everytime I get gas, on of my most creative and functional mods yet.
Brian
Brian
You also might look at Stillen.com to get some ideas of "shrouds" used to direct airflow on IC on the 300ZXs.
The Carravagio cannards should direct some air in there as well--see avatar.
I've had twin IC since early 2003 without problems.
Scotty, (NemesisC5)
Thanks,
Thanks,
Brian
Brian
I like your approach to things like this Brian, utilizing the technology of the SPA gauges to trigger a very effective and proven method of cooling. Air + Water =
St. Jude Donor '08
[QUOTE=NemesisC5;1559288258]Clayton, I think attaching ducts to close them in would cause higher heat while in traffic and around town. I think it could only be beneficial while highway driving, in that case as you said it would give you higher air volume by capturing the air thus giving the "ram air effect. IMHO, I would leave off the brake ducts as I believe ATI recommends. Use Alky to give you lower than ambient temps while in boost(if you haven't already)
Thanks for your input. I think you are right about causing heating problems around town. By the way, I do have alky injection. Never can be too safe.
Brian
Brian
also this system is MUCH cheaper than the N2O spray bar type systems and should cool the intercoolers for longer periods.
thanks Chris.
Your intercoolers are right in front of your wheels.......
Please don't spray them down, while at the race track PLEASE.
The last thing I want is water in my lane, in two patches that happen to be the same as the tire tracks.
The only cars I have seen spray water on the intercoolers.
The intercoolers are mounted on either the top of the motor, or out in front, in the middle.
If you do it, just be mindful of where the excess water goes.
EA
EA
1 Post
St. Jude Donor '08
Isn't where the ATI intercoolers go the same place where Lingenfelter and APS put theres? Are the ATI intercoolers a similar size and design-I mean if it's good enough for LPE and APS it's gotta be a pretty decent place. I've often thought about swaping over to this setup to clear up the area infront of the rad.
Former Vendor
EA
EA
Brian
When done correctly with the right size nozzles and pump psi, a fine mist is generated, by the time the mist passes through the IC, it has vaporised but I hear what you are saying. Guys, we are not talking about garden hose style spraying, a very fine mist, nothing more.
Brian
Brian
Brian, I definetely caught your drift Bro Maybe you could think about offering a kit, might be a good marketing angle for moving some SPA "intercooler temp in/out gauges". I'm pretty sure some of us guy's in the deep South could use it
Those gauges already exist. I know SP Engineering has them, lots and lots of supra owners use them.
And yes, mist no big deal. But then there will always be that guy that thinks bigger is better, and I can just see it now.....and if the intercooler isn't hot enough, to evaporate the mist, it's still going to collect and drip.
Still to me this is a none issue, but hey, I guess to each his own I guess. One of the main cars to use that system, also has the intercooler in about most heat soaked area of a car. (TOP OF THE MOTOR)
EA
Happy Boooooooost'n
EA
Happy Boooooooost'n
EA
We added the fans on this C5 in an effort to drop the inlet air temps after extended track use where this car is being used on a road course.
http://www.exoticperformanceplus.com...Car.php?car=40
The owner was noticing a large drop off in power after repeated laps with a lot of wide open throttle use. We don't yet know if the fans will help while on the track, but they should help to cool the intercoolers down once the car is pitted. Bob
St. Jude Donor '08
JMHO,
