Meth injection, run b4 or after the MAF, what about the IAT?
I have a Stage I TTI and want to run meth. Currently, my MAF is right before the TB. I was told meth will kill my MAF, so I am going to relocate the MAF further upstream. Now, I want to keep the IAT sensor after the meth so I get the full benefit from the cooler charge. So two questions:
1) Will the meth kill my IAT sensor?
2) If it won't, how do I separate my IAT sensor from my MAS? What wires do I splice? Is the IAT sensor a dealer only part, or can I get one from Autozone?
Anything I should think about first?
Colby
Colby
Colby
Colby
Well, I'm told that meth is corrosive to metal, and considering the MAF has metal wire in it, I'd guess mixing the two would be bad.
Not sure about the rest.
Supporting Vendor
1 Post
You should spray the meth after your MAF. As far as I know, nobody here runs it before the MAF and I can only imagine it would do real funny things to your tune if methanol was spraying through the MAF. Eventually it would cause the MAF to fail because methanol is corrosive, but I think it would take lots, and lots, and lots of boost and methanol to do this. Heck, I bet I could fog methanol onto a MAF sensor for several weeks straight and it would probably still work fine (just a guess). So I wouldn't be as concerned about the corrosion as I would the MAF sensor reading funny while meth is spraying. On the plus side, your MAF sensor would never get oily.
You can get an IAT sensor from GM for around $20. If I recall correctly you are splicing into the brown wire coming off the MAF sensor to break out your IAT. Meth will not kill the IAT sensor.
There are pros and cons to spraying meth through the IAT sensor. Know that artificially low IATs will affect fueling on your car (usually by the end of a run most guys are seeing 20-30 degree drops from ambient temperature). I don't think this is by any stretch an issue but it does throw things off a little bit, probably more so if you ever go to a speed density tune. On the plus side, if you spray through your IAT sensor your tuner can sort of use that as a safety mechanism in your tune. Since your car won't really see high IATs while the alky is running he could make sure the car pulls a bunch of timing if it did see high IATs (e.g., methanol ran out or pump failed or whatever). I don't have meth on my car yet but will probably tune my car this way.
1 Post
Meth changing phases will drive MAF crazy causing you to go pig rich if not pegging it. Then never mind corrosive nature.
IAT you can use any 3K thermistor (I’m 99% sure it’s 3K @ 25 degrees C). If you want I can double check.
Mike
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
Thats how we tune our alky cars that are relying on the meth for fueling (high hp cars were we are trying to get the most out of it) Like Tony said, that way if you were to run out or have a problem timing gets pulled way back and the chance of a serious problem is very slim.
Correct, which is why in my '04 I need to splice in a separate IAT sensor. Sounds like most any GM IAT sensor will do. I assume two wires go to the IAT sensor located within the MAF? Do you know what color wires these are?
Colby
So on the '04 MAF, both the MAS and IAT sensor share a common ground. So if you split them, you'll need to supply an additional ground or splice into the common ground.
Colby
Colby
Jer.
I spray meth after the MAF and since I have an 2004, its after the IAT also.
I'm not an expert, but I would tend to think that meth before the IAT could or might fool the computer into believing the incoming air charge is cooler than it really is and allow more timing, even too much? Then kaboom!
Supporting Vendor
1 Post
Nah, the IAT vs. timing table only retards timing when it gets too hot. It doesn't advance timing. So as long as you're tuned safe to begin with this is a non issue IMHO.
FYI, part numbers
25036751 AC Delco IAT Sensor
12102620 AC Delco Wire Pigtail
I'll be putting it all together tomorrow and I'll post some pics.
dave
dave
