PTS/PTK turbo kit owners, please read.
So, the million dollar question is :
How the hell do you physically get to the spark plugs for #2 and #4 cyclinder without disassembling half of the driverss side exhaust piping??? Can't reach them from the bottom (downpipe in the way), can't get to them from the side. And can't even see them from the top... Also, where did you get your plug wires? I have tall valve covers and the coil packs on top of the valve covers (pic in my avatar). I've now gone through 3 universal plug wire kits to try and get enough parts to construct plug wires that will work. None of the companies I can find sell universal kits for LS1's.
Thanks,
Derrick
Thanks,
Derrick
Thanks,
Derrick
Thanks,
Derrick
Take off left front wheel.
Insert long extension over top of shock tower, with "wobbly" spark plug socket. I use electrical tape around the "wobbly" section so that it just flexes and is not loose. You can access both (#1 & #3) spark plugs from this location.
To get the plug boots back on, you can reach #1, but for #3 I usually pop the oil filter off so that I can get my arm up there from underneath the car. I like to feel them snap into place.
Before I had my lift I did it from a creeper on the garage floor and jack stands....I had it down to 1 hour to remove and replace all of the plugs..that was from the time it took to put the car on stands and put it back on the ground ready to drive.
I haven't got a change to try it with my lift....I can't wait.
Once you know how to do it or have done it a few times...its not as hard as it seems....like anything else.
