Racetronix fuel pump Problem
I recently installed a ECS NOVI 2000 with the Racetronix fuel pump, hot wire kit and 60 lb injectors. I have put about 500 miles on the car. this morning on the way to work, cruising along, the car just dies. I noticed a loss of fuel pressure and checked the fuse going to the pump. This is the 20A fuse near the alternator. It is blown I replace it and the car starts back. The car runs fine, but then dies again about a block from my house. Went to replace the fuse and it blows immediately. Obviously there is a short somewhere either in the power supply leading to the pump or inside the pump itself. The only thing that I can think that I did this weekend that might remotely affect the pump is washing the car and filling the fuel tank. Anyone had problems with a pump shorting out internally? I have a hard time believing the wire running to the rear is shorting out. I zip tied it to the fuel lines.
BTW I posted this in the FI section due to more Racetronix users in this area.
Chris
Chris
