Turbo Tuning HELP NEEDED - Back to Track Tomorrow
I recently bought a TT vette from Texas Speed & Peformance. It is a 99 FRC 347 forged built with 9:1 compression and has blower cam (224 duration and 600 lift) and upgraded heads. The turbos are 57 mm and part of a HP TT kit. It supposedly dynoed 780 RWHP but it did not fair well at the track the first time out. It ran 12.32 at 116 with 10 lbs of boost and 93 octane pump gas. If I had to guess this was around 430-460HP at the wheels.
Here's what I have found and cured since then, replaced all the plugs as three of them well oil/gas/carboned up and it had a slight miss under a load. The driver side header downpipe had an exhaust leak and the methanol pump injection was not working due to a faulty fuse.
Also, the IAT sensor is laying up on top of the intake manifold and not plumbed into the intake track, according to my scanner it was reading 142' air when the ambient air temp was 90'. The total timing was only 11-12' at WOT, I relocated the IAT to the front of the intercooler and total timing jumped to 15', although I did not keep it there thinking the tune was set up for the higher IAT temp reading.
I know I need to get a wideband meter hooked up and have the tune re-done but until then I'm looking to see what else I might be able to do to pick up the power level until then. I plan to go back to track tomorrow for some more test runs and was planning the following. Let me know what you think.
1) 8lbs IAT on top of manifold pump gas
2) 8lbs IAT on top of manifold race gas blend
3) 8lbs IAT moved to front of intercooler w/ race gas blend
4) 10lbs IAT moved to front of intercooler with race gas blend
5) 12lbs IAT moved to front of intercooler with race gas blend
Should I run or not run the meth injection with the test cases above? The plugs that were bad were #1 and #2 thus I was thinking perhaps the meth injection was blowing out the fire or causing too rich of a mixture and causing them to carbon up?
I'm new to the turbo world so your thoughts suggestions comments or ideas are greatly appreciated.
Run the meth no matter what. It aint causing the plugs to foul.
If it were me, I wouldn't run it without a wideband telling me the tune was at least track worthy. Fyi, I had a buddy who was chasing ping forever. The problem was his timing was too low
Arnel
Arnel
Do you have some type of scanner software to monitor it. such as EfiLive, Hp Tuners, AutoTap, etc? This would at least give you an idea as to where you're at to start with.
If so, you could hook it up and monitor knock retard and timing, IAT's, and many other variables before taking it to the track and possibly damaging it. Just a thought.
Thanks for the advice, I'll run the Meth pump just to be safe. Curious why you buddy's car was detonating with the timing too low is that possible?
I told him what it ran at the track and he recommended I get it dynoed to see where it was it. We all know that ET slips tell us more about real world power than a dyno. He did not even have a boost gauge in the car.
