Sneek peak!!
Old 08-31-2007, 08:55 PM
chriswtx
chriswtx's Avatar
Default Sneek peak!!
Sneek peak. It will fire up tomorrow....Or blow up... All work done (attempted) by me..
Old 08-31-2007, 09:00 PM
eb02z06
eb02z06's Avatar
St. Jude Donor '08
Looking good bro!
Old 08-31-2007, 09:33 PM
LB
LB's Avatar
you are a champ
Old 08-31-2007, 09:39 PM
chriswtx
chriswtx's Avatar
Thanks...Now if only I could find my stupid MAP sensor.. It seems to grown legs and walked off...
Old 08-31-2007, 09:49 PM
Skunkworks
Skunkworks's Avatar
Looks .
Good luck on completion.
Mike
Old 08-31-2007, 10:56 PM
BLOWNZO6
Premium Supporting Vendor
BLOWNZO6's Avatar
Looks great!!!
A lot to be said for doing it yourself.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old 08-31-2007, 11:03 PM
chriswtx
chriswtx's Avatar
2 week project that stretched out into an 8 month one
Old 08-31-2007, 11:28 PM
KorbenDallas
KorbenDallas's Avatar
Did you build the motor yourself?
Old 08-31-2007, 11:52 PM
NemesisC5
Support Corvetteforum!
NemesisC5's Avatar
Originally Posted by BLOWNZO6
Looks great!!!
Props to Ya Bro
Old 09-01-2007, 12:07 AM
hpcubed
hpcubed's Avatar
Very nice!
These things take time to do right.... especially when you have other priorities that call you "Dad".
Old 09-01-2007, 01:06 AM
chriswtx
chriswtx's Avatar
yes, built it myself down to the custom ground cam to my specs from Compcam.
Motor details
347ci, Eagle LS1 6.125" rods, Diamond -8.6 dish pistons, stock crank, new LS6 block, ARP head studs, custom Comp Cam 226/232 116LSA, Texas speed CNC LS6 stage 2.5 heads 2.04in 1.575 ex valves that I took apart and hand finished, Kooks 1 7/8" headers, ECS meth kit, ported Weiand intake, Will put me right at 9.5:1 compression... Doug at ECS said it will make an easy 750rwhp...
Old 09-01-2007, 01:08 AM
chriswtx
chriswtx's Avatar
Originally Posted by hpcubed
Very nice!
New baby in the house. She just turned 6 months old... I think I went through 6 months of postpartum depression
Old 09-01-2007, 01:11 AM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,099 Likes on 810 Posts
Motor details
I am betting on 800rwhp and if less that 750rwhp is not what we want and you better call me so I can come out for the firing up
Old 09-01-2007, 01:26 AM
jbsblownc5
jbsblownc5's Avatar
2017 C5 of the Year Finalist
St. Jude Donor '08
It takes a lot work to do things yourself, but when I do, I know it's done right...
Good luck on the fireup!!!
JB
Old 09-01-2007, 05:32 AM
RJW
RJW's Avatar
Location: Tinker till it blows... then back it off a notch, maybe!!
St. Jude Donor '08
Nice job bro....
Ported oil pump w/ shim???
Drivetrain mods?
Are you gonna break it in easy, semi-easy or at 20 psi wot to seat the rings quickly?
Should be a monster Is that your break-in sc nose pulley?
Old 09-01-2007, 10:31 AM
chriswtx
chriswtx's Avatar
Yep, Ported the oil pump myself and added the shim..
Drivetrain mods? Just the DTE brace and hardened left output shaft...
Are you gonna break it in easy, Yes, 500 easy miles first...
Old 09-01-2007, 10:47 AM
vetterlatethannever
vetterlatethannever's Avatar
Lookin' good, I bet it's gonna run insane!
To Sneek peak!!
Old 09-01-2007, 02:31 PM
LV Vette
LV Vette's Avatar
St. Jude Donor '08
I’m not an expert by far, but when I put on the DTE brace and the hardened drivers side output shaft, I then went to the track and broke the passenger side output shaft. After looking at it, I don’t think it is much stronger then the driver’s side. So while you’re at it, put in the passenger side hardened output shaft.
JMHO,
Clayton from Las Vegas
Old 09-01-2007, 02:57 PM
chriswtx
chriswtx's Avatar
JMHO,
I had thought about it when I did the driver sides shaft, but I'm pretty easy on my drivetrain and not much track use. And the $500 for the little short side is crazy If it breaks I will upgrade the whole rear end and tranny all at once...
Old 09-01-2007, 03:04 PM
RJW
RJW's Avatar
St. Jude Donor '08
I say do it all now and sell me your hardened shaft...
Quick Reply: Sneek peak!!
