can you run i 6 rib belt on a 8 rib pulley
Old 01-18-2008, 06:09 PM
2002 MATRIX SC
2002 MATRIX SC's Avatar
Default can you run i 6 rib belt on a 8 rib pulley
can or has anyone run a 6 rib belt on a 8 rib supercharger pulley?
Old 01-18-2008, 06:16 PM
DALLA1
DALLA1's Avatar
yes i did it for 2 years and never had a problem!it is perfectly fine!
Old 01-18-2008, 06:24 PM
Cliff99C5hardtop
Cliff99C5hardtop's Avatar
I'm in the process of finding out myself.......just got my 8 rib today and tryin it out Sunday.
Old 01-18-2008, 06:31 PM
Mopar Jimmy
Mopar Jimmy's Avatar
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
MATT,
At your nice power levels would make sense to spend the $50 and got an 8 rib belt, if your getting an 8 rib pulley, to insure that the belt won't slip when you launch as far into the 10s as you possibly can this season!
When in this deep this is about the cheapest mod that I can think of that will help you meet all your goals on your maggie boosted Roadster!
Old 01-18-2008, 06:43 PM
2002 MATRIX SC
Originally Posted by BLOWN ECS Z06
MATT,
well on the maggie, to go smaller then the 3.0 pulley that is already on the car you have to machinr the snout to exept anything smaller, and i was just going to buy one that is already machined that came with a 8 rib pulley, jim if i could change all the other pulley's , including the crank pulley for $50 i would of already done that, but i think it would cost at least $1300, for a new crank pulley (overdrive) and the other pulleys,
Old 01-18-2008, 06:45 PM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
Absolutely. I just finished putting my ECS overdrive pulley on. It is an 8-rib. It wasn't in the budget to make all of the rest of the pulleys 8-rib, so I am running a 6-rib and will be for a while I am sure.
Old 01-18-2008, 07:25 PM
Mopar Jimmy
St. Jude Donor '06
Good point, a brain lapse on my part as its been a long day downtown for me today and i was thinking the pulley/belt systems on centrifical supercharger and not a maggie!
Old 01-18-2008, 07:32 PM
2002 MATRIX SC
cool, but my set up would be the oppisite, as the 8 rib would be on top, (supercharger, and 6 rib stock balancer, you think it would still work?
Old 01-18-2008, 07:55 PM
madmatt9471
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I'd say if all your other pulleys are the 6 rib (Which I hope I'm right in this assumption) and you have the 8 ribber then you should be good as they, all the other 6 ribbers, will keep it all lined up correctly!
It looks as if others have done it and you'd should be good as well
Thanks,Matt
Old 01-18-2008, 09:40 PM
2002 MATRIX SC
Thanks,Matt
that is the case all other pulleys are 6 rib, exept for an 8 rib on the snout of the supercharger, thanks, Matt.
Old 01-19-2008, 12:52 AM
BLOWNBLUEZ06
I still say you'll have no issues with an 8 rib on the Maggie and 6 rib belt. Most important is alignment, second, is belt wrap. (mine used to throw the belt when I grabbed gears at high rpm until I added an add'l idler).
Old 01-22-2008, 10:19 PM
vetfun98
vetfun98's Avatar
Default 8 rib
Ran a six rib belt with a 8 rib balancer all last year. Upgradeing to a full 8 rib system this year.
Old 01-22-2008, 10:32 PM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,099 Likes on 810 Posts
The $1300 is about right, I know I just got in my 8 rib pulley kit for my winter modding
Old 03-15-2013, 08:53 PM
zackyv55146
3rd Gear
zackyv55146's Avatar
I know this alil old but I wanna do the same im looking for a 7.65 8 rib. Crank pulley could somone send me the link to one plz? And would I be ok to run my 6 rib harmonic balancer??
Old 03-15-2013, 11:03 PM
Varmit
Varmit's Avatar
St. Jude Donor '08
same here
Old 03-16-2013, 03:09 PM
_zebra
_zebra's Avatar
yep - there's a camaro guy who just swapped his crank to a 10-rib but is still 6 with everything else - no problems. just make sure it's lined up right & has good tension
Old 03-16-2013, 04:21 PM
zackyv55146
3rd Gear
Ok if I could just get ur help one last time could I purchase this and be good to go then?
http://www.innovatorswest.com/833-LSX-Damper.html
Old 03-16-2013, 08:30 PM
_zebra
_zebra's Avatar
i might be wrong, but last i heard the F-body balancers don't work with our cars because the vette accessories are a different distance away from the block
Old 03-16-2013, 08:47 PM
zackyv55146
3rd Gear
Im pretty sure right i just wanna makee sure that crank will work with a 6 rib harmonic balancer before I go off and spend 600 bucks lol
To can you run i 6 rib belt on a 8 rib pulley
Quick Reply: can you run i 6 rib belt on a 8 rib pulley
