Gauges necessary for Maggie and nitrous? Stock look?
Former Vendor
What gauges are necessary for the Maggie?
What gauges do you need for Nitrous?
As far as autometer it seems like the Nexus gauges are close to stock. If I got the Nexus gauges I would either install matching bexels on my dash gauges or try to paint the nexus gauges black. I really want my maggie and nitrous gauges to look stock.
Received 2,113 Likes
For the S/C you do not need any gauges. They are nice to have and I went with Boost/Vac and Fuel pressure.
Don't know for sure about Nitrous but probably FP and Bottle pressure.
I guess you could say that about every gauge in the car. You do not need any gauges in the vehicle at all to drive it; however, they are essential to monitor proper operation. I would think a boost gauge at a minimum. Especially if you ever drive your car at lower ambient temperature so you can know what's going on with the boost. I guess it's just a little more important for me not having a forged bottom end yet.
Now having a Boost gauge on a FI car is half the fun.
The fuel pressure gauge will alert you to any problems that may develop with the pump and or boost-a-pump and possibly save your motor by you seeing that something is not right.
To a lesser degree the boost gauge can also alert you to problems such as leaks/pressure loss due to loose/leaking ducting, slipping belt, etc.
I disagree, IMHO a fuel pressure gauge is a must and a boost gauge is helpful as well.
I took my car to the track last weekend for the 1st time. I glanced at the Boost but can't remember looking at the FP during the runs. Before and after I checked but not during.
Maybe I was just too busy holding on and having fun.
Former Vendor
http://www.autometer.com/cat_gaugeli...&opid=1&szid=2
Can someone please explain the difference between boost/vacuum and boost and which some is better to have with a Maggie?
All engines run in vacuum unless they are being forced fed.
With a Boost only you will be able to see the boost psi. Whereas with the B/V you can read your vacuum when you are just cruising not getting on it.
As I get on it a little I can see the vacuum drop towards zero then it goes positive when it starts making boost.
St. Jude Donor '08
Nitrous you are concerned with Bottle pressure, Fuel Pressure and AFR.
I log fuel pressure using EFI Live, and have a combination gauge from Trick Performance that combines Bottle Pressure with AFR. This gauge has the option to use either AFR, Fuel pressure, or Boost as an input (in conjuction w/ Bottle pressure).
Here you can select a real time w/ a six second history graph of your "second" input (AFR, Fuel Pressure or Boost).
Here is a movie of me cycling through the menu's with the guage running.
Beer working the Trick Performance Gauge
The second input (AFR, Fuel Pressure or Boost) has the ability to program upper and lower limits, shutting down the nitrous if needed.
