How do I tell if I have a boost leak?
The car has the 3.4" pulley for the A&A Vortech setup, which corresponds to 10 pounds of boost. I am seeing 10 pounds of boost exactly at redline. If max boost is achieved exactly at redline, does it mean that I don't have a boost leak?
I'm only asking this because after a dyno the shop owner/dyno operator said he thought I might have a boost leak, and my car also appears to be running rich. The car only made 491 rwhp with the 10# pulley, long tube headers and no cats.
I believe how much Boost you generate is relative to each set-up an individual has...
What I mean to say is - your compression level, how well your heads flow, your engine size...these things will all determine how much boost you generate with a 3.4" pulley versus the next guy with the same size pulley. And yes, your peak boost should be reached by when you hit your peak RPM.
My NOVI, with a 3.5" pulley made 10 pounds. (I dyno'd 625 w/ this one on.)
With a 3.25" pulley it made 14 pounds.
I'm in the middle of trying to firgure of what it will do with a 3" pulley.
I hope this helps, good luck.
I do agree htough that a boost leak test should be the first thing to do. it will eliminate ALL the guess work and tell you EXACTLY whats going on.
I mis-understood the q. Hitting max boost when losing the boost reference to the WG is causes runaway boost. I think the original question should be " will the boost be lower if there is a boost leak "
Your final outcome should be more than the 491 RWHP so this is why he is supspecting a leak somewhere.
Thanks,Matt
Hope this helps.
Search all through your plumbing and look for tears or holes or loose parts or clamps.
Then check your BOV and make sure it is not openning or is staying open while under boost!
Thanks,Matt
Regardless of a B@@ST leak or not you will have a MAX B@@ST level but it will be higher when there is no leak present.
Hope this helps.
Thanks,Matt
Hope this helps.
Thanks,Matt
As for the BOV, you might want to remove it and make sure it's sealed when it has no vacuum on the diaphragm. Make sure the gasket or seal isn't bad too.
Forgot to mention that if someone with experience with your exact combo is involved, they might know what a specific pulley should yield for boost and they then should also know what kind of power it should make assuming the tuning is proper.
The best way is just to make sure that all your plumbing is tight and not have any tears and holes or loose clamps that would allow B@@ST to excape!
Now as far as the By Pass Valve you need to see if under BOOST it closes and stays closed!
So you may need to remove it and put the 10 lbs of pressure into the vac line to see if it closes and does not leak and take your finger and push against the blade to simulate the pressure put on the blade to keep it closed too and push against to try to make it open!
Thanks,Matt
Received 2,379 Likes
check under the car. boost will stain your pavement.
