Anyone want a transmission that will hold your F/I, nitrous power???
#122
With the C6 cradle, it sets the centreline
Of the wheel in the wheel well towards the
Back by 5/8". Any way of getting it back to
Center ?
I had a set of 28" Mickey drag radials on
the car at the dyno, and the passenger side
went through the inner fender, hit the bracket
and flipped it..... the screw dug into the tire to
the cord.
I am replacing it, and am going to run a
1/2 mile event with them, anyone else run into
this problem ?
Would changing A arms change the centreline ?
Center ?
the cord.
this problem ?
#124
Center ?
the cord.
this problem ?
Center ?
the cord.
this problem ?
#126
I will say in advance that I haven't personally done it, but a couple of forum members have reused their C5 arms and coilovers to keep the tire in its original place.
#127
Which A-arms? if you use C6 top A-arms it will put it farther back than using the stock c5 upper A-arms... I am using the lower C6 A-arms and the wheels are a tad back... and it looks sort of stupid.
#128
The only way I see this getting to the correct position would be to lower the car substantially and when the camber is corrected in the alignment the wheel will go forward.
The other way is to use an eccentric type bolt on the rear.
#129
Center ?
the cord.
this problem ?
Center ?
the cord.
this problem ?
#130
I'm missing how lowering the car moves anything forward. You would have to change the caster angle to move anything forward.
#132
Lower the car, it squats... (more camber), since the adjustment is the front leg of the a-arm, it will push the wheel a tad forward when you correct the alignment.
The new C7 has adjustment on both legs of the lower A-arm.
#136
St. Jude Donor '15-'16-'17-'18
The exhaust will not clear the outside of the diff. I cut 3" sections out of the x-pipe and added those pieces on the humps. No clearance issues. I cut the x-pipe before the hangers (to get the straightest pieces) and had to move the hangers, but that wasn't a big deal.
#137
was trying to avoid hacking my corsa extremes.
any one know if we can boltup a c6 exhaust?? and avoid it?
#138
Supporting Vendor
It's not going to simply "bolt up" though. You'll have to re-engineer it some.
#139
