Anyone want a transmission that will hold your F/I, nitrous power???
#141
Supporting Vendor
If you need offset mounts to complete your build, send me a PM. That also goes for stock tranny and motor mounts.
I've got plenty in stock for you.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
#142
Anyone use the 2009+ cradle with C5 arms? Wheel are offset back quite a bit. Does the 2005-2008 cradle with C5 arms put the wheel exactly back in center of wheel well?
zrtman1 (03-11-2016)
#144
I've not compared any cradles to any others. I guess that I got lucky when I purchased a 2008 cradle for my setup. Using C6 arms with the 08 cradle, my wheels are farther back than stock, but not by that much.
#145
I think the mounting location is set back more with the 2009+ cradle vs the 2005-2008??
#146
Received 1,261 Likes
mine looks about the same as yours and I'm using the older cradle with 2 slots on each side, c5 arms, and lg gt2 coilovers... it appears slightly moved towards the rear compared to when it was stock but not as much as the 6060 swaps I have seen that are using c6 arms
zrtman1 (03-29-2016)
#147
About to supercharge my car. 02 C5Z. Setup will be longtubes, V3Si, Mild cam. Do I need to worry about my rear end right now???? Please advice as I'd like to do all the work at once. Thanks!!!
#148
Thebonly way to put the wheel to the fron is to use eccentric bolts for the top a-arms. When you fix the camber with front bolt it will bring it back to the front.
#149
The only way you need to worry about your rear end is if you have broken clutch springs (which I see every time I take a stock differential apart) or if you wheel hop.
#150
#151
Supporting Vendor
