Depends on what turbos you're using as to if and how much of a restrictor you might use. Are you blowing oil?
The company who makes the kit should already have this issue worked out, but if you bought up-grade turbos or the turbos were not in the kit, they you have to get restrictors that are for your application.
I'm not blowing oil but I am getting low oil pressure.
I have the TE-44's which came with the kit from what I know.
As you probably know, journal bearing turbos need more oil than ball bearings.
I would get with tech support at Precision Turbo and Engineering or some comparable company and see what they recommend.
I had to put oil restrictors on my car after getting it back from the PTK install. I have the te-44 also and my car smoked like a freight train without them.
I just talked to precision turbo's and they said i wouldn't need them on journal bearing turbo's. Is there a reason why you put them on? Were you getting low oil pressure without them?
I wasn't getting low oil pressure there was just to much oil going to the turbos and every time you gave it any throttle it smoked a ton. I know Nick Yoskin also had to put restrictors on his PTK kit because of the smoke.
