Harmonic Balancer and FORCE Induction??????
OK I want to put in a new Harmonic Balancer since i got to do the cam bolts. whats the best Harmonic Balancer i seen some in flee bay from $120 to 200. they are fluid fill and sfi certified.
i was looking at the SLP one but it say is under drive 25% whats the deal with belt size and does it make the super charge make less power thanks also post Ur current Harmonic Balancer is the stock good enough.
Oh i forgot to post my set up ECS SC making HP and 479tq not looking to step up yo a more rib system just want to see if i should upgrade stock to save my main bearings and prolong engine life and performance.
talk to ECS about an overdrive ballancer, cost is close and you get a nice boost increase with less belt slip, it is also 8 rib so in the future you can go to an 8 rib setup. also the stock one is prone to causing problems and underdrives are for NA/turbo cars not SC (you lose a lotttttt of power on a noviee with underdrive)
