*NEW* RPM Transmissions LEVEL 7! 4L65/70E
Former Vendor
INTRODUCING RPM Transmissions new level 7 4L65/70E Transmission. This transmission is designed for all out street/strip applications. We have fully tested this new design transmission in house with our shop C6Z06 at full weight with 700 RWHP. It has over 50 9 Second passes with ZERO failures!!! We have also tested this transmission in our other shop C6 twin turbo car with over 830 RWHP, and several other customer cars that have reported similar results including a full weight GTO that runs in the 9’s. We developed this transmission to fill the gap between current 4L65/70E transmissions and the 4L80E.
RPM Transmissions Level 7 Transmission
Parts with * are Level 7 Exclusive
Media Blast Transmission Case
RPM Sleeved Input drums
RPM 3-4 Clutch pack
RPM reinforced sunshell with collar and bearing
*NEW Extra WIDE Heavy Duty double caged 29 element sprag
4L65/70E low roller clutch
Billet 4th gear servo
Transgo HD2 shift kit
*Billet 2nd gear servo
Carbon Wide band
Updated aluminum accumulator piston
Bushing kit
New shift solenoids
New wiring harness
New GM valve body spacer plate
GM 5 pinion planetary sets front and rear
300M Hardened Output shaft
*300M Hardened Input shaft
*Billet Pump Rotor
Billet Overrun Piston
*Billet Forward Piston
*2-3 HD Apply Valve
*QUICK TIME SFI Approved Bellhousing
*Deep Aluminum pan
*Micropolished Internal Parts
**Corvette comes with converter drive plate as well.
$4495.00
Level 7 option-
Pro-tree transbrake $795.00
RPM 3-4 Clutch pack
Carbon Wide band
Bushing kit
New shift solenoids
New wiring harness
*Billet Pump Rotor
*2-3 HD Apply Valve
*Deep Aluminum pan
$4495.00
Level 7 option-
Received 1,762 Likes
RPM 3-4 Clutch pack
Carbon Wide band
Bushing kit
New shift solenoids
New wiring harness
*Billet Pump Rotor
*2-3 HD Apply Valve
*Deep Aluminum pan
$4495.00
Level 7 option-
RPM 3-4 Clutch pack
Carbon Wide band
Bushing kit
New shift solenoids
New wiring harness
*Billet Pump Rotor
*2-3 HD Apply Valve
*Deep Aluminum pan
$4495.00
Level 7 option-
Killerrrrrrrrrrrr You guys have gone a long way to restore credibility to the 4L60. Should give a prize to the 1st 8sec pass.
Since the SFI bell and deep pan are included, looks like about a $900 increase from Level 6 to 7.
Former Vendor
The converter completely depends on the application. Give us a call if you are needing some direction and we would be glad to help out.
Thanks,
T.J.
Thanks,
T.J.
That's funny, I thought just the opposite on the application:
A $4495 Level VII trans is targeted for one specific application.
But I guess somebody might put this baby behind a bone stock LS1.
Seriously, thanks for the hard work on the 4L60 platform.
Most everyone builds parts for a turbo 350, 400, or a glide. But not a 700R4 type.
And I definitely need some direction...
HOT DIGGITY DOG!
as always nothing but the best from the hard working guys over @ RPM!
RPM 3-4 Clutch pack
Carbon Wide band
Bushing kit
New shift solenoids
New wiring harness
*Billet Pump Rotor
*2-3 HD Apply Valve
*Deep Aluminum pan
$4495.00
Level 7 option-
RPM 3-4 Clutch pack
Carbon Wide band
Bushing kit
New shift solenoids
New wiring harness
*Billet Pump Rotor
*2-3 HD Apply Valve
*Deep Aluminum pan
$4495.00
Level 7 option-
St. Jude Donor '08-'09
Geez.I haven't even got down the track yet with my new combo and my level 5 is outdated!Oh well.Maybe by the time I get out there will be a level 10.Nice to see RPM is always one step ahead.
