Flip Drive + iron block. How many have done this?
Old 12-29-2010, 03:11 PM
0Chris@HPS
Former Vendor
Chris@HPS's Avatar
We have installed a few Flip drives and they work great! No issues and no belt slip. We have a customer with a F1r running 21-22psi consistantly every pass with a 8 rib setup. Used the same belt for a month before racing season ended with out issue.
Chris
Old 12-29-2010, 05:37 PM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
Originally Posted by Neil B
Can you tell from these photos if my block already has the holes drilled?
I can tell by the bottom picture that you'll need to drill a hole. It's where there's a little ear hanging off the side of the block where the cylinder head meets the block.
Old 12-29-2010, 06:31 PM
Neil B
Neil B's Avatar
Good info. Thanks!
Old 08-30-2012, 10:21 PM
Zeus-of-Boost
Zeus-of-Boost's Avatar
anybody have the drill and tap sizes. cartek said that they were going to send me an email but never did. im about to do this project myself.
Old 08-31-2012, 08:10 AM
c5austin
c5austin's Avatar
The DP Direct drive was a 8.5 drill and a M10X1.5 tap I believe
Old 09-05-2016, 11:47 AM
all4spl
all4spl's Avatar
what was the solution to this problem? I have been fighting a belt squeal and i looked at the alternator side of my cartel flip drive and noticed that the flip drive pulley doesn't seem to be aligned straight with the power steering and alternator. I'm wondering if that is the source of my squeal. I have the lq4 and don't have the third hole.
Old 09-15-2016, 07:09 AM
Atrain59
Atrain59's Avatar
I have been debating on whether to just do a full 8 rib set up or go to a direct drive since I have to drill and tap my block also.
Quick Reply: Flip Drive + iron block. How many have done this?
