Nick Williams 105mm throttlebody
jobberone
I've a friend who has installed a few. I received instructions from Williams on how to change the tune to allow proper idle etc. You lose some driveability with slightly sluggish throttle response times with large throttle blades. You do need a blade and throttle body slightly bigger than your intercooler outlet ID. My intercooler outlet ID is 91mm. I'm going to use a ported LS7 TB at about 96mm along with a FAST 102 manifold for instance. But I drive my car more than I race it. If you want all out then you will get a little more volume of air with the larger TB.
Received 1,762 Likes
