Big Dawgs Locater
Big Dawgs Locater
Heres a lil map I put together for us to see where each other is. Add your self to the map if you wish. It could be a useful tool in planning road trips as well as it will let you click on someones marker and map it. Hopefully I got the bug worked out that made it default to Houston.
BigDawg Map
If you add a shop please use the candle marker. That way we can keep them easy to access visually. Also please add all contact info for that shop should you add it. Thanks
BigDawg Map
BigDawg Map
BigDawg Map
Awesome idea! Count me in!
