Which size headers for AA SC kit
Going to be installing my SC soon and am looking into which size headers get. I've read many threads about 1 3/4 vs 1 7/8. What is the consensus which a SC? I've heard the 1 7/8 can be a PITA to install. Would they be overkill with 7-8 lbs of boost? What is hard about installing the 1 7/8 headers? Obviously they are bigger, but what needs to be done differently?
I think Powerlabs did a back to back comparison of 1 3/4" VS: 1 7/8" on his blown LS2 and found no appreciable gains or losses. My opinion: Get some ebay headers and call it a day. Spend the money you save on other go fast parts.
Nothing really needs to be done differently with the installation of the 17/8th vs the 13/4 (I installed a set of 17/8th on my old c5z on jack stands). As for the difference, you *may* see negligible gains compared the two since you are on a stock block and the stock a&a system so I would get whatever you can find the cheapest. You really only start see gains from larger primaries when you start moving a TON of air (ie: very high boost, larger blowers, etc)
1 3/4 will work fine for what you are going to run. If you plan to upgrade your motor and add more boost, you might want to go with the 1 7/8. My 1 7/8 AR headers went in just as easy as the 1 3/4 LGM headers (maybe a little easier), both where a little of a PITA.
If you simply change the exhaust and nothing else, you will likely lose midrange power and gain slightly in top end power. If a tuner maximizes a tune on 1-3/4 headers and then changes to 2", and maximizes the tune again, more power will be found.
http://forums.corvetteforum.com/c6-f...er-tricks.html
I would just go straight to the 1 7/8 headers. Why not get the larger ones the first time? You may decide you want more power down the road where the 1 7/8s will show better gains.
They are the same price, aren't they?
701 RWHP on Kooks 1 3/4" headers here and still have room to grow
Thanks,Matt
Thanks,Matt
I have 1 3/4" but if I had to do again I would go bigger from the get go.
I do need to mention that I made over 900RWHP using 1-3/4 Dynatech headers and thats what I've been running all along. Part of my winter project is changing those to 2" headers, which I just received today.
I may have trouble measuring gains because I changed my blower intake and will be changing pulleys too, but I guess I can take the old dongle and pulley with me and try to measure the difference.
