I also would like to know, I have one from cca, the supporting vendor. It's sitting in my room with the rest of my supercharger parts
I have one of these as well and I have seen bolt onto the furthest pass side block bolt. I have an A&A and am wondering if you slide the mounting bracket behind the s/c bracket bolt if it would slightly mis align the belt.
That's more of the question I was asking, can I mount it in the same spot it normally goes with an A&A kit?
