Video of my car on the dyno/ big fireball
Got my blower cam and a&a p1sc kit finished up a few weeks ago. Car has
Lg superpros, O/R xpipe, Corsa extremes
A&A p1sc 8psi
EPP Blower Cam
ECS AlkyControl
Walbro 255, KB BAP, 60lb Seimens
Monster Stage 3 Clutch
It made 566rwhp@6460rpm/ 485lb/ft@5400 on a mustang dyno, with 16 degrees of timing. This number seems very low to me by the way but it pulls like a train.
Heres the dyno vid, pretty big fireball at the end
http://www.youtube.com/watch?v=5MWzr...el_video_title
And heres an idle video of the epp blower cam
http://www.youtube.com/watch?v=jXe4J...el_video_title
A&A p1sc 8psi
EPP Blower Cam
ECS AlkyControl
1 Post
Sounds great, I had the same setup, minus the cam and made 657/562 @ 8psi on a dyno jet which will be higher. I was running more timing than you though (21*) which is more aggressive. Your tune is probably very conservative which is a good thing.
Very nice run and as many have said the Mustang numbers are usually much lower 30-50 RWHP in most cases -
See what it does at the track and that will make you happy!
Thanks,Matt
Thanks,Matt
Thanks guys. I'm thinking of getting a smaller pulley and giving it some more timing and see what it puts down. Should be fine since I have the meth
