A&A SC.. What gears are y'all running?
I'm having SC put in next week an wanted to have gear an stall put in before they tuned it...
Was wondering what y'all were running?
Any info would be appreciated..
What I got: Pretty much stock.. Longtubes, FAST 92 an ported TB. A4 w/ 3:15..
Having A&A SC installed.. Later on plan to do heads cam ect... Wondering if I should do gears an stall with SC install or have gears an stall done with heads cam install? Which one would be more beneficial?
An what gear an stall would be best for what I'm doing?
Thanks Kris
Thanks Kris
I don't have a SC yet but will be adding an A&A kit soon. I have an A4 with a 3.42 diff and a Yank SS3200 stall. All my research has indicated that it will be a good combo for the SC.
Hope it helps.
Hope it helps.
Thanks Kris
Thanks Kris
Here is the one I have on mine:
http://www.makcotransmissionparts.com/4739-1.html
I have no issues at all, here is a chart to see the difference in ratios and RPM Vs MPH:
Thanks,Matt
Hey thanks for the replys...
I understand an always heard 3.42's but my question being since I have 3.15's now an 3.15 an 3.42 being so close of a gear. Should I change from 3.15 to 3.42 now.. Then when I get heads cam ect. upgrade again from 3.42 to a lower gear again?
Or would be better to stay 3.15 an once I do heads cam upgrade to the lower gear then an only change the gear once?
An the tranny cooler is a must an will be put on..
Thanks for the reply guys..
The 3.42's I did over my 3.15's were very noticeable and I love them, I will not ans would not go any lower!
Look at my Sig below and you'll see the stages I went through and I began with my stock 3.15's then went to the 3.42's all the way through!
I am finishing up my STAGE 7 right now
Thanks,Matt
Received 1,762 Likes
Stay with the 3.42's with the A4, going lower on our A4's does it no good.
Thanks,Matt
Thanks,Matt
Very good points.. I see more clearly about why not to go too low of a gear.. Thanks alot..
Madmatt your throwing up some very nice number with a A4.. Very nice car..
I have 3:15 with a stall. I thought about going to 3:42 but all i do now is spin so I question going lower. Maybe if I dragged the car regularly and used slicks but not on the street, that is just based off my driving style though
Yeah I'm debating to change the gear now or wait an see how it is with the 3.15. Since I getting a lifetime tune anyways.. But I tried calling the guy installing the system to get his advice but he was out driving a car. I'm not doing any racing with it. I'm just wanting to have a smile put on when I'm driving it..
But I'm am doing the stall an tranny cooler..
I'll throw another angle in.....
When you/they install the SC the whole front of the engine will be apart. That's a VERY GOOD time to install a cam. If you wait till later for the cam all the front has to come off again anyway...... heads I don't think are quite that critical (timing wise).
Honestly, you're going to have so much more power after the install I don't think you'd be able to make a good decision about the gears for 6 months to a year anyway.
Spend your money in a more logical manner first.
JMHO
JMHO
St. Jude Donor '15-'16-'17-'18
JMHO
JMHO
Yeah I see yalls point.. I guess I'll do the cam as well.. Since it's going to be torn apart. What cam specs are y'all running? If y'all don't mind telling.. I want the most insane cam I can put with a SC.
Thanks for the info guys. Y'all have informed me more then I was expecting..
Thank
Thank
I run 3.73 gears & a pro yank extreme 3400 stall converter & its a handful on the street, I can lightem up @ 70mph on 17lbs of boost, pending on how much boost u run would be the determining factOr on which gear , if its low run more gear , if its high run less,btw do as I say not as I do,i tend to take it to tthe extreme
what gears?
I swapped out my 2.73 for my 3:42 gear ratio..huge difference. no stall and with these gears you wont need them. all you will do is spin more and tear up more stuff. If I had kept my 2.73 or stepped up to 3:15 them maybe a stall would be in order. also did the cam while the car was apart for the supercharger install. had a custom blower cam installed by HorsePower Sales in Pompano. car dynoed at 525rwhp on a Mustang dyno. I have been told that if I would take it to a dynojet dyno it would dyno about 40hp more on average. car is a beast. when I smash it while doing 40 or so it downshifts into passing gear and all hell breaks loose..tires and all. really too much for street tires. If I were to go with drag radials I would probably lose my transmission and eventually my axles since they have not yet been upgraded. You dont want too much traction unless all your drivetrain has been upgraded. edramos.
