Dyno Results T-trim Stock Shortblock
Great #'s. Our set ups are close.
03 z06
t trim 4.0 pulley
FAST92/ ls2 90 stock heads
alky dual nozzle
tex z grip
lg pros no cats
torquer v3 cam w/ dual springs
FAST rails
255lph pump
BAP
I have been thinking about going with the 1" shorter rad and new inlet pipe on the s/c. I spoke with A&A and they don't believe that this mod adds anything to the overall power. What's your thoughts on this mod? Obviously you did multiple things at once to your Z (gutted cats, more tuning, inlet pipe).
I need to schedule some dyno time!!!
03 z06
t trim 4.0 pulley
alky dual nozzle
tex z grip
lg pros no cats
FAST rails
255lph pump
BAP
That mod was worth the effort to me b/c pulleying down was not a good option. Otherwise I probably would just do that.
I believe mine is the newer dongle. They advised me against going with anything other than a 4.0 pulley (stock internals). I think the mod would be worth it plus I noticed this summer that my temps would go up (really hot days). That never happened prior to the s/c. I really want to either forge this motor or go with a 408 forged and pulley down.
AFR on the dyno according to my wideband was in the high 10's the whole time. It leaned out to low 11's once I hit the street.
I am not running a stock balancer. I don't believe you can with an 8-rib setup.
I have 100's of runs with this setup making in the low 700's already. Hell, maybe over a 1k.
I hope it continues to hang in there I guess if it doesn't detonate it will survive for the most part
Well, I have a spare shortblock already. I might not use it, but I intend to put a new motor in there in a year or so. Without detonation I'd expect it to just develop a little blowby or bend the rods. I spin in to 7k sometimes also. I'm willing to just see what happens.
AKA "The CLOWN"
That is great to see a stock bottom over 700 and holding well. I am shooting for 700+ as well in the spring, Just hope my motor likes 14lbs of boost with race fuel, other wise I will have the coolest looking LS1 coffee table!
Lots of people are doing it. Obviously the tune has to be great and/or conservative. Then other factors come into play like how well your rings are seated, etc. That is my thinking on it anyway.
AKA "The CLOWN"
Doug (ECS) will be retuning my car in the spring, so I feel very confident in his tuning abilities!
Former Vendor
#34
Former Vendor
#35
It really made a HUGE difference. AFR was 11.5 back when it made 690, and relied on meth for enough fuel. The wideband was pegged past 10.0:1 after adding the line with no other changes.
#37
I remember when I used to think 14# was a lot.
