Anyone ever modify there D1SC/P1SC/ with aftermarket impellers for more hp?
Old 10-09-2016, 03:27 PM
stevieturbo
stevieturbo's Avatar
Just look at it, it's obvious how it comes apart.
And you've highlighted the allen key that secures the impeller on....just undo it to allow you to press the shaft out via the back ( after removing other gear and circlip for teh bearing in the gearcase )
Old 10-10-2016, 01:16 AM
MrBigDee
MrBigDee's Avatar
Thank you for yor reply. Now I know the demoliton order.
I´m trying to open using the allen key but it is tight and I don´t know where I can hold on the impeller shaft not turning?
Which direction the impeller nut open? counter clock wise or counter wise?
Old 10-10-2016, 12:42 PM
stevieturbo
Stick a coin or some soft metal inbetween the gears to help lock them for undoing the nut.
Often the nut will loosen in the same direction of impeller travel. I havent specifically took apart your blower, so really it's just a case of trying each way.
I doubt it is threadlocked, but a little heat before hand would do no harm just in case ( not blow torch heat...maybe good warming with a heat gun.
Quick Reply: Anyone ever modify there D1SC/P1SC/ with aftermarket impellers for more hp?
