Auto Swap Thread
Old 01-08-2012, 11:33 AM
corvette8189
corvette8189's Avatar
Originally Posted by CHIWS6
how much have u spent so far on the swap?
I bought alot of parts used but all said and done ill have around 8-10K
Originally Posted by 4DRUSH
What are all the bolts coming down through the floor pan for?
and where can I buy a pair of those pink jack stands?
Bolts are part of my 6pt. cage and the stands are red not pink ****** camera.
Originally Posted by Z06wanted
When I did my auto conversion it was a PITA but was best mod I done. You will love dragging Bret down the interstate in Mexico. lol Auto for the win.
Old 01-08-2012, 03:15 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Support Corvetteforum!
MVP'S ZO6's Avatar
Billy are you gonna go and lay the smack down on Bret at the track?
Old 01-08-2012, 03:19 PM
Blitzkrieg
AKA "The CLOWN"
Blitzkrieg's Avatar
Brett is probably doing the swap as we speak and keeping it a secret!
Old 01-08-2012, 03:54 PM
corvette8189
You better believe it
Old 01-08-2012, 04:26 PM
dascorcha21
dascorcha21's Avatar
i like where this is going haha
Old 01-08-2012, 04:52 PM
MVP'S ZO6
MVP'S ZO6's Avatar
let me just say I wouldnt be supprised.
Old 01-08-2012, 09:44 PM
02402ramair
02402ramair's Avatar
Sure they are
Old 01-08-2012, 10:10 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
pic of seal plate? Thats why i posted this. i dont think i have that
I would do a C6 Z06 differential with your combo. Mechanically speaking the install isn't too bad. Biggest PIA is to add in extra connector for auto transmission, but it seems like you're going with a stand alone controller.
Lots of guys running A4's in the C6's go that route.
Old 01-08-2012, 10:12 PM
dascorcha21
in order to do that his new tranny would have to be a 31-spline.
Old 01-08-2012, 10:32 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Yes, but it would be a much strong combo. I think the shaft is around $595 and the rear adapter is $550.
I was going to do my Z06 this way but decided I would just sell it and wait for the C7's.
I've done a few of these conversions. The C6 Z06 differential is just so much better than the C5's and the costs off sets would more than make up for the $$$ it takes to beef up a c5 differential.
Old 01-08-2012, 11:11 PM
corvette8189
Anybody have pic of there swaps or auto stuff in general post it up or pm me.
im sticking with the built c5 diff for now, hopefully it holds pretty well.
Old 01-08-2012, 11:24 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
I hope it holds up for you. The C6 Z06 differential is better mounted (two mounts) that stops all of the pivoting (side to side) movement that leads to cracked cases.
There's not much to post up. It's a fairly straight forward swap.
Drop the drive train out.
Pull out the pilot bearing
Install Flex Plate
Swap Tranny harness out.
Install the new stuff.
I see you have a scattershield, you might need to clearance some of it to clear your exhaust.
Also do no not torque down the spline shaft until you let it warm up and adjust. Just tighten to hand tight.
Other than that you'll need to run some cooling lines and add a trans-cooler.
Never did an external controller so that should be different.
Swapping pedals isn't that bad. Takes about hour. Just pull out the drivers seat and flip youself in the car on your back with feet hanging in the back.
Most time consuming part is adding wires and moving pins on PCM connectors.
Also you need to weld in bracket in the trans tunnel for shifter cable.
Old 01-08-2012, 11:48 PM
  #33
4DRUSH
4DRUSH's Avatar
I run a C5 rear with 500m harden shafts. Ruined a couple gear sets & twisted/broke a couple 300m shafts over the years, but never broke the case. I also have a billet pass. side cover which I think helps. (plus a ECS trans brace of course)
At the track- make sure your rear tires are on the damp edge of the water box for your burn out. Anything beyond that area is hard on parts. Also adjust your rear view mirrors so you can see if both tires are spinning, bad for clutch packs otherwise.
You should also get the ECS axle loops, cheap insurance if you break an axle.(also NHRA rule)
Old 01-09-2012, 12:20 AM
  #34
Chris Stewart
Chris Stewart's Avatar
Yeah how about a diff brace? Also, your trans needs a shift lever like this.
Here's a similar thread if you haven't seen it: http://forums.corvetteforum.com/c5-f...onversion.html
I ran -6 braided lines to a big front mounted cooler. We tried an electric fan cooler in the back, but it wasn't enough to keep temps under 200.
Old 01-09-2012, 03:36 AM
  #35
baezi z06
baezi z06's Avatar
sorry for stealing threat
Can a manual ECS trans brace be used whith the AUTO ? or are there different fastener on the tranny ?
Can a A/C console be used as a big transcooler ?
great threat BTW.
thanks
Baezi
Old 01-09-2012, 07:12 AM
  #36
ajg1915
ajg1915's Avatar
St. Jude Donor '08
great threat BTW.
thanks
Baezi
No to the brace as the mounting points are different.
I would not recommend using A/C Condensor for cooling, they make aftermarket radiators that you could use, like Dewitts.
Old 01-09-2012, 08:43 AM
  #37
baezi z06
baezi z06's Avatar
Brace : but are they in same length ,if i make new mountings for the Auto
just the A/C Condensor sound so good if it could be used.
It´s very big and fitts right back on , no problem at all
thanks
and again sorry for stealing the threat
Baezi
To Auto Swap Thread
Old 01-09-2012, 09:57 AM
  #38
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
Uhh. That's not gonna happen.
He's about to find out that that's the only place the car will be effective.......except there ARE a few hondas that haven't been crushed yet. Loser gets the Pink jack stands.
Old 01-09-2012, 10:47 AM
  #39
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Install Flex Plate
I got alot of parts from this guy he knows what he is talking about here. Plus if I can do the swap with only help setting the cradle up to bolt it and the trans in any one can do it for sure. But again mine was a A4 to start with no wiring to swap out are chg.. I dont see Bret doing the chg out just a hard core race guy for sure.Robert
Old 01-09-2012, 12:20 PM
  #40
a/c man
a/c man's Avatar
They do make a A4 trans brace also!
Quick Reply: Auto Swap Thread
