Sometimes when I get bored........I build another car
Hey Bret, post up a pic of my F1R when you get it out of the box so we don't confuse the folks here with that pic of the massive F1x.
The F1X is definitely bigger then the F1r.
The F1X above is NOT going on my car. Mine is just a little F1R...
Knew this was going to happen
Seems like 900whp builds are becoming the norm on here with the YSI's and the F-series s/c'ers. Glald i'm already there at 24psi boost with my F-1c.
Very nice build and your in good hands(Bret). Just make sure Bret doesn't talk you into getting 250 or 300 shot of pills.
Supporting Vendor
Yeah, it's a wee bit hot at times, but we go from air conditioner to air conditioner, so it's no big deal. I would much rather deal with the heat than the cold. Besides we have the best Mexican food in Texas!!
Supporting Vendor
No juice going on this thing yet.
Here's more pics of the work I've gotten done so far. I'm about to run out of stuff to do until the motor gets here. I also installed a Tick master, but there's not much to see of that. I forgot to mention that I'm installing a Mcleod RXT on the car too.
new fuel system install is complete. The Boost A Pump was already in place. I cleaned it up some and moved it over to the secondary pump. I put a Lingenfelter pump in the tank along with a Racetronix harness.
I clearanced the rear cover to get around the new bulkhead fitting that I installed in the tank.
Keeping with the theme under the hood, I put some braided loom on the Alky Control line and painted the brass check valve
This is all you're going to see of the factory fuel system under the hood. No tees no regulators.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
Received 1,762 Likes
ttt
Bret, really do like the fuel set up on this under the hood. I am going to have to copy this soon man. Hope you dont care man. I have to clean all of my crap up under the hood like moving the coils and new tall set of V/covers. This is going to be one nice build.. Robert
Was the previous 622whp setup running methanol injection? I'd like to go the supercharged route, low to mid 500s, but the prospect of blowing the engine in less than 20k miles keeps me worried.
Yes I had the Alky Control kit on it when it was stock engines running 100% straight meth. We have no idea why the stock #5/7 pistons lost the middle ring lands. No obvious melting or detonation clues were apparent....just two chunks of pistons gone. Everything else was absolutely perfect in the engine.. Afr was never leaner then 10.8.
Knowing what I know now, I would keep the boost no higher then 8psi on a stock engine.
You're using the stock line plumbed into the MagnaFuel manifold along with the secondary fuel feed. Is it safe to assume the two 90° fittings on the manifold will go to each rail? Will you remove the factory return line? I like it.
#34
Supporting Vendor
I'll start setting the intake up today. I'm quickly running out of things to do. Somebody better hurry up with the motor or else I might get bored and repaint the car a different color!!
#35
Gonna be a mean SOB
Good luck with the rest of the build guys I say 920rwhp pump+meth 18psi
So who's F1X is that? I think someone is looking for 1200rwhp without the nitrous
#37
If you're sure you want a pic of it posted up next the the F1X, I'll do it, but I'm afraid you'll end up feeling like the Burger King guy with the hands.
I had no idea until I put them next to one another
#38
#39
When adding a turbo, blower or spray, one usually opens up the top ring gap so it doesn't close up, butt together and break the ring land.
Do you know if that was done on this engine Alan?
To add coolant to the back on an LS6 you can add a front coolant crossover turned around. The hose plumbing might be a bit tricky, but I'm working on that.
Ron
Ron
