Sometimes when I get bored........I build another car
Supporting Vendor
AJROTHM's Z06 Gets a 403, F1R and a serious makeover
I figured you guys might enjoy following along with me through my current build. I have been doing builds for other members for years, but haven't posted much about them since I wasn't a supporting vendor. I only do a few a year. I really enjoy them. I do one at a time so I can give it my full attention. As many of you know, I recently finished ALGZ06's 9.5 second car.
AJROTHM contacted me a few months ago after his motor went soft on a couple of cylinders. It's a silver 2002 Z06 with a D1.
It started out as just a motor swap and tune. Since we share the same disease, it's evolved in to a really exciting setup. We're doing an iron 408 with a Callies crank and rods, Wiseco pistons, MAST heads, a cam from Arun, F1R, 10-rib, Dewitts Radiator, reusing the LS6 intake, 1000cc injectors, revamping the Alky Control system, and doing a custom fuel system that I designed from scratch.
Here's a few pics.
Removing the engine
Frame cleaned up
Cradle cleaned up
Fender removed to set up the fuel system
factory fuel pump out
custom fuel system and new Alky pump
Here's a few pics.
Removing the engine
Frame cleaned up
Cradle cleaned up
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
Here's a few pics.
Removing the engine
Frame cleaned up
Cradle cleaned up
Here's a few pics.
Removing the engine
Frame cleaned up
Cradle cleaned up
Thanks for starting a thread Bret. I was going to do a full build thread once we were further along to prevent a long, drawn out, boring build thread but.....Since we're rolling with it, here is some more pics of some of the stuff...
First, this is what we started with...Stock LS6 and a D1SC w/10 psi, made 622rwhp. Lasted 4k miles before #5/7 bit the dust:
Now the new stuff:
New LQ9 6.0 iron block w/Arp studs
Mast Motorsports 245cc heads w/hollow stem SS intake valves and Inconel exhaust valves. Heads flowed 355/245 cfm @ .600" on a 4.030 bore
Callies Compstar H beam rods
Still waiting on crank and pistons...
American Racing 2" headers
Some crappy pics of the F1R..(maybe Bret will post some good pics of it when he opens the box)
The engine combo will be:
402"
9.8-1 compression
Mast 245s
Stock LS6 intake
Callies Compstar rotating assy.
Wiseco pistons
ARP studs through out.
Arun STG 2 blower cam
Other mentionables are an Arun 10 rib setup to go with my A&A bracket, IW 10 rib, 10% OD balancer, Dallas Performance Direct drive, 4" intake. Dual Nozzle Alky Control meth. McLeod RXT clutch, Tick MC and most important is Bret's custom fuel system that he designed (based on what I wanted)....
I'm excited about the build, The car has been down since early March of this year, I figure we are still 2 months out from completion. I will be updating the thread as we go as I am sure Bret will too.
Thanks for looking!
Now the new stuff:
402"
9.8-1 compression
Mast 245s
Stock LS6 intake
Wiseco pistons
Thanks for looking!
Received 1,762 Likes
ttt
Looks like a nice start, also like the looks of the fuel system. As alway It will be one bad azz ride for sure.... Robert
I knew that...hahah. Imagine if Arun, you and me work together me being assistant....would be kick azz, being an Lic auto Tech and years of experience, would have been great. I love working on cars its like getting paid for passion, my only sad part i dont have garage like you and arun, had to rely on Arun or my friend's single garage.
Looking great bret as usual.
Supporting Vendor
This car is going to be sick!!! Can't wait for the end result.
