custom 88mm single turbo c5 progress
Old 06-21-2012, 12:32 PM
livetocruise
livetocruise's Avatar
Default custom 88mm single turbo c5 progress
Well, finally going to sit down and post up a few pictures/progress of my 99 c5 vette with a custom 88mm precision turbo mounted up front, custom intercooler, and all custom piping. The car is coming along very good however we still have a few hurdles to get over (any input would be appreciated!) We have to run the oil supply/return from the turbo, have to fab up a power steering resevoir, find a proper length belt that will work the the custom tensioner we have made, etc etc, and worst of all, I have to pull out the clutch slave cylinder (yet again) as since we put the motor in, it appears that either I or someone else stepped on the clutch pedal with the motor out, and blew the slave! So any input on a fully custom clutch setup (master/slave) would be appreciated. Preferably something that eliminates that damn "easy connector" on the drivers side. Many MANY more pics available, but here are a few teasers!
Old 06-21-2012, 12:36 PM
livetocruise
also the turbo is a precision 8884 with a 1.23A/R in the T5 tang hounsing (essentially a T6). it is a MONSTER! ceramic ball bearing, cea wheel, etc etc.. if it makes boost prior to 4k rpm I should be happy!
Old 06-21-2012, 02:51 PM
Jay_Rich
Jay_Rich's Avatar
Nice! awesome work! Cant wait to see it complete.
Jay
Old 06-21-2012, 04:42 PM
venomws7
venomws7's Avatar
Very nice looking setup man.
What engine size? Trans? How are you going to mount the radiator?
Old 06-21-2012, 09:11 PM
nullpointer
nullpointer's Avatar
I've been dreaming of a setup like this
Old 06-21-2012, 10:31 PM
livetocruise
the engine is an LME built 402 9.4 compression with trick flow heads. The entire driveline came from DTE, the trans is their second step down from their best setup, and the rear is the top of the line. It has a spec dual disc clutch (that was used with the old motor, but looks as though it will still hold up) (I hope).
Old 06-21-2012, 10:32 PM
livetocruise
depending on the numbers this kit puts down, and the "driveability" of it, we may attempt to market it by next year, but that is still many moons (and many hurdles) away!
Old 06-22-2012, 10:32 AM
nullpointer
Good luck! I will be watching if it every comes to market with good results
Also what size DP are you going to run? any frame cutting? where the hell is the filter going to go lol
Old 08-21-2012, 01:19 AM
BLWN1
BLWN1's Avatar
any updates?
Old 08-27-2012, 11:09 AM
nullpointer
Originally Posted by BLWN1
any updates?
bump
Old 08-27-2012, 12:09 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
pic,s and update... Robert
Old 08-28-2012, 12:29 AM
BLWN1
BLWN1's Avatar
The headers look similar to the obx I tried on today. If I could weld they would probably be a pretty easy set to use in a race car setup...
Old 08-28-2012, 03:47 AM
FourG63 97GST
FourG63 97GST's Avatar
the obx turbo headers? how was the fit? a/c compatible?
Old 09-10-2012, 09:40 AM
BLWN1
BLWN1's Avatar
My car is a race car, not even close. This kit is what I need..... waiting for results, good luck guys.
Old 09-19-2012, 06:42 PM
livetocruise
the headers are not obx, they are 100% home built. The car finally has all of the loose ends tied up, (I think) I have gotten my efi live software today, and just got through some setup issues, however now have the rough file installed (thanks to doug at ECS) and will begin slightly finer tuning to allow for break in of this thing prior to it's first visit to the dyno. Will begin working on the file tomorrow!
Old 09-19-2012, 07:43 PM
BLOWNBLUEZ06@RKT Performance
Supporting Vendor
BLOWNBLUEZ06@RKT Performance's Avatar
great work!! That should make some serious power!
Old 09-20-2012, 08:24 PM
TriplBlk
TriplBlk's Avatar
To custom 88mm single turbo c5 progress
Old 09-20-2012, 09:00 PM
livetocruise
hit another snag... I have to find a way to integrate my LM2 wideband controller into the EFI V2 controller. I do not have the original O2 sensors in the car, so I need to figure out how to log the A/F ratio into EFI live. I am sure it is possible, however if any of you know how, it would save me some digging!
Old 09-20-2012, 09:05 PM
livetocruise
here's a current pic today after I washed it off for the first time in a LONG time!
Old 09-20-2012, 11:36 PM
BLWN1
BLWN1's Avatar
Smaller, relocated radiator? Looks killer, wish you had made 2!!!!!
Quick Reply: custom 88mm single turbo c5 progress
