Starting My TT Build (PIC Heavy)
Old 06-22-2012, 11:31 PM
redneckvette
Support Corvetteforum!
redneckvette's Avatar
Default Starting My TT Build (PIC Heavy)
Here goes;
I bought this 99 Arctic White FRC (Already Cloned) with the intention of this Twin Turbo build.
I pretty much have all the parts allocated at this point;
* Forged 382 purchased from forum member John Carter.
The following is from the original post when John had the motor for sell here on the forum:
This engine was built by Cartek in NJ. Had two build identical and this was the spare that never got used.
382 CID Stroker
Callies Crank
Eagle Rods
Diamond Pistons
Double Timing Chain
ATI Damper
Corvette Oil Pan
Upgraded Oil Pump
All forged internals.
The same as the Engine I ran in my convertible...See it and hear it run on you tube:
http://www.youtube.com/watch?v=DYWXESnE-XM
http://www.youtube.com/watch?v=G0uFI86nvYQ
Dyno with 450RWHP motor only
* 317 heads and ZR1 gaskets, Comp Cams dual springs
* Custom Turbo grind cam (thanks to Bret for the help with the grind)
* LS6 Intake, FAST rails, 80lb Injectors
* 07 C6Z trans and three rib diff all sent to RPM, Level 5 trans and and level 4 diff.
* C6Z Clutch/PP/Throw out bearing. Remote bleeder
* STS kit with the following upgrades Turbonetics T3/T04B .48 A/R polished turbos with ceramic ball bearings
Tial waist gates and BOV, WERX pump, electronic dual stage boost controller
* Fuelab Prodigy pump, pressure reg and filter. in process of mounting to factory hanger.
* DeWitts Radiator
* Alkytrol Dual Nozzle Meth Injection
* Tons of stuff I can't even remember buying at this point
I have thus far removed the complete drive train and am currently working on the fuel system. I'll post more pictures as I go.
Wish me luck!
Old 06-23-2012, 05:29 AM
baezi z06
baezi z06's Avatar
Originally Posted by redneckvette
Wish me luck!
good luck
Baezi
Old 06-23-2012, 07:58 AM
helga203
helga203's Avatar
Here goes;
I pretty much all the parts allocated at this point;
* STS TT Kit upgraded to Ceramic Ball Bearing
* DeWitts Radiator
Wish me luck!
Go mother f'er go. Don't drink and build you'll get done alot faster.
Old 06-23-2012, 09:20 AM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
Good luck man and like you said more pic,s as you go with her.. cool looking car... Robert
Old 06-23-2012, 09:46 AM
Zeus-of-Boost
Zeus-of-Boost's Avatar
this is going to be a bad azz build.
Old 06-23-2012, 12:31 PM
Yellow03Z06
Yellow03Z06's Avatar
Looks like fun! Why bother with a C6Z clutch with the power you will be making?
Old 06-23-2012, 02:04 PM
Chris Stewart
Chris Stewart's Avatar
good stuff
Old 06-23-2012, 03:26 PM
jerrad
jerrad's Avatar
God I love that color! Good luck with the build, it'll turn out amazing.
Old 06-23-2012, 04:26 PM
redneckvette
Well... I have no intentions of putting slicks on and going to the track, those days are past for me. I have a Speck clutch that came on the car that I could use, but I was hoping to get a less grabby clutch that would hold up to street use... Do you think the C6Z is still a bad idea for street???
Old 06-23-2012, 04:27 PM
redneckvette
Thanks!
Old 06-23-2012, 04:31 PM
redneckvette
Thanks... When I started looking for an FRC, I was really wanting black, but this one came up and really caught my attention... It has really grown on me and it's easier to keep up with..
Old 06-23-2012, 05:35 PM
BLOWNBLUEZ06@RKT Performance
Supporting Vendor
BLOWNBLUEZ06@RKT Performance's Avatar
Very cool. Should be tons of fun when it's done.
Old 06-23-2012, 06:31 PM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,096 Likes on 808 Posts
Very nice and get a ZR1 Clutch over a Z06
Old 06-24-2012, 11:39 PM
bradenW
bradenW's Avatar
Nice car and will be a fun build. I wouldn't recommend the z06 clutch either.
Old 06-25-2012, 12:17 AM
redneckvette
Going to see if I can exchange for the ZR1...
Old 06-25-2012, 12:25 AM
redneckvette
Thanks! I will see if I can exchange... I bought the clutch very early on thinking I would only build a 500-600hp car, then the disease took hold and well, here I am with the potential for a little more than 500 or 600hp...
Old 06-25-2012, 12:51 AM
redneckvette
I'm still fab'n my fuel pump hanger, hope to post pics on Thursday. I have the Fuelab Prodigy Series 41402 good for 1300hp with the boost referenced FPR that links to the pump to electrically control the pump output.
To Starting My TT Build (PIC Heavy)
Old 06-25-2012, 07:39 PM
redneckvette
Here's what I made today!
Old 06-25-2012, 08:05 PM
madmatt9471
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Nice job - everything is looking real good!
Really liking the Fuel System!
Thanks,Matt
Old 06-26-2012, 09:26 AM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
Thanks,Matt
Impressive!!
Quick Reply: Starting My TT Build (PIC Heavy)
