Not enough power... Opinions welcome
Finally got car ready for a dyno tune. It done alright but was expecting more power out of my set-up. But I suppose I need to either up the boost or look into better heads. Im pushing 12psi through twin billet wheel 62mm turbos to a 408 stroker, 9:1 compression , turbo cam, lq9 heads , spraying meth also. It put down 722rwhp and 719 ft lbs. I was expecting to atleast make 850rwhp. What would be a safe boost pressure before lifting the heads? Here's a link to dyno sheet and dyno pull. http://s1232.photobucket.com/albums/ff373/Jcbrown86/
Supporting Vendor
Is it speed density tuned? I'm sure your combo is capable of making more power and worst case scenario, turn up the boost to get there. What are the specs of the "turbo" cam? What kit do you have?
I was the same way when I got my car back wasnt even close to what I thought I should have made for power but the car has quite a few issues and was sent back to have them fixed and figured while it was there putting a 3.55 pulley on from a 4.00 pulley and hopefully great numbers from that switch.... I am currently in a ls2 auto with a d1 and made 704/637
Rick
Rick
Yeah Im thinking 20psi should get me where Id like to be, And its a HPP twin turbo kit, front fender mounted turbo's, Not sure cam specs, ill have to look at build sheet. Its not a speed density tune either.
5 Liter Eater "Bill" has a 408 with TTIX Kit and he makes 850/900 @ 19 psi..if you go from 12 psi to 20 psi you should be where you want to be.If you have any questions PM 5 Liter Eater,he can help..Good luck and nice setup
Supporting Vendor
A boosted 7xxRWHP setup on a MAF tune is something that I don't recommend to my friends. The only way to do it is to scale the tables way back. It "works", but causes issues with other tables. At 20psi, I would plan on ditching the MAF tune and re-tuning the car.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
Former Vendor
St. Jude Donor '12
Corvette Camaro GTO GM Truck Performance tuning in Tampa
Your going to run out of room on your MAF table with boost. On some lower boost packages you can tune around it some depending on the PCM unit and how you want to lie to the MAF and make the correction in the PE table. Some will reset when you run out of MAF and some can still look at the PE table for some trickory. Really not a good way to tune.
You can only recommend what to do as a tuner to guys that have already spend $10 grand on a FI package, and they look at you funny when you tell them to spend a couple hundred more for a 2 or 3 bar MAP and a custom operating system for the tune.
The MAF only doesnt have to believe your lie once, and the next build you'll spend $10, 600 bucks lol
www.TampaTuning.com
Phil
Former Vendor
when we uild the TT motors there not 9.1 there a little high comp, the lq9 heads are also holding you back also. a good set of TF or AFR heads will wake it up a TON. I didn't know you were just lq9 heads. Safe pressure is figured with not just your static compression, but also your Dynamic compression. You n eed to know both and boost level to get a good est of where your at. You need to know your cam specs to figure it all out, but with just the lq9 heads your getting close to lifting, maybe 2 more PSI. Once you get your cam specs and get some good thick deck heads on there you will know what you can push then, and you will be a TON higher on HP. and yes at that level you will also need a SD tune. I would expect 15 PSI and AFR heads to be in the 850+ RWHP range with your setup. Dont forget the motor combination has a TON to do with HP. The heads, intake,and cam all need to be speced for your build for it to perform at peak levels.
here is a TT vid of a camaro we just did. The cam is a cam made for this type of build, and the car is only on 9 PSI. The car is a ls3 so it has alot better heads than lq9 heads, and yes the comp is higher, but dont forget its less CI and less psi. its all about the combo and how it all works together
ISIS SUCKS FAT CHOAD
I would try raising your static compression ratio. 9.0 assuming that's what it is is a little on the low side jump up a half a point or so and then crank up the boost.
Supporting Vendor
well here is also a few things i forgot to mention the other day.
I've seen plenty of cars make 800+RWHP using stock heads. I've seen plenty of cars make 900+ (even a few 1000+RWHP) using the stock intake.
OP, if you were wanting more power in the beginning, it would have been wise to get your car SD tuned unless the change to SD is going to be free.
Honestly the numbers sound about right to me for 12#, perhaps a scosh on the low side. Do you know how much timing is in it? With 93 + meth I would shoot for ~17-18 degrees, especially with that low boost. I would not be afraid of raising the boost even with the 317's. My 408 is ~10.2:1, unported 317 heads and ebay head studs and I have run as much as 19# through it. The heads and downpipes are a definite power bottleneck for me.
Im not sure about the timing. But im probably just going to look into a nice set of heads, any suggestions? and what injectors would be an upgrade from 82#, i was maxxing the 82's out.
There are some good heads for sale here: http://forums.corvetteforum.com/c5-p...630-heads.html
What size are the HPP downpipes? The 2.5" downpipes on the TTIX kit are a restriction.
You must not be spraying much meth if you're maxing out 82#ers. I guess I would go north of 1k injectors if you're going to replace.
