Dynoed the car today 730 whp p1sc!
Old 09-22-2012, 07:00 PM
fotoboy
fotoboy's Avatar
Default Dynoed the car today 730 whp p1sc!
Stock ci on e85
I was expecting 650ish. Boy was I surprised
Belt slip at 6200 too, I thinks w a secondary drive I could break 750.
CorvetteBrent (04-05-2020)
Old 09-22-2012, 07:27 PM
p1bz
p1bz's Avatar
Nice...
Old 09-22-2012, 09:49 PM
madmatt9471
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Not bad, not bad at all! E85 id good stuff!
Any more details on your set-up?
Thanks,Matt
Old 09-22-2012, 10:27 PM
Milan
Milan's Avatar
How much timing?
Old 09-22-2012, 10:51 PM
95wht6spd
95wht6spd's Avatar
Setup details?
Old 09-23-2012, 03:46 AM
fotoboy
fotoboy's Avatar
Thanks,Matt
Patriot heads, 228 232 595 574 114 cam, ported fast 92 1 3/4 long tubes total Wot timing is 16 deg at 12 psi.
Old 09-23-2012, 08:07 AM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,099 Likes on 810 Posts
Awesome results
Old 09-23-2012, 08:08 AM
Its Bruce
Its Bruce's Avatar
What compression ratio?
Old 09-23-2012, 11:47 AM
fotoboy
fotoboy's Avatar
Originally Posted by its bruce
what compression ratio?
10.75
Old 09-23-2012, 12:08 PM
madmatt9471
Very cool,thank you!
What size pulley you running on the P1?
You have the flip drive, 8 rib belt setup?
Again very nice results on your setup.
Thanks.Matt
Old 09-23-2012, 12:23 PM
fotoboy
fotoboy's Avatar
Thanks.Matt
1st gen a and a bracket, 6 rib, stock balancer, no flip drive yet, 3.4 upper, treadstone ic, iat never broke 90 deg in a 70 deg shop.
Old 09-12-2019, 08:37 PM
corvet786c
corvet786c's Avatar
some people are using a d1 and cant get those numbers, great job.
Old 09-13-2019, 06:53 AM
Turpid porpoise
Turpid porpoise's Avatar
7 year old thread...
mykream (09-17-2019)
Old 03-30-2020, 08:13 PM
LucassZ06
2nd Gear
LucassZ06's Avatar
What fuel system were/are you running on the P1SC vette? I have an 04 Z06 with a p1sc and want to run E85 but don't know exactly what size injectors and what fuel pump to run. Thanks in advance!
Old 04-05-2020, 03:09 AM
CorvetteBrent
CorvetteBrent's Avatar
Default Your question
This is an old thread from 2012, so, if you want an answer to your question, send the original poster a direct message and maybe he will respond.
Old 04-05-2020, 10:29 AM
frc00ny
frc00ny's Avatar
Then post it all up here please.
I have the A and A P1sc-1 kit. a similar cam, 3.85 pulley (makes 11 psi with stock heads and intake), Cartek flip drive, Kooks 1 7/8 headers, 3 inch exhaust all the way to the tips, boost referenced return style fuel system with 255lph pump from the original A and A kit, with the racetronix hotwire kit. But i was only 532 rwhp and 479 rwtq. Each tuner has stated that i was running out of fuel. I assumed they meant that the system was inadequate rather than just injector pulse width being maxed out,(60lb injectors from kit)
Not complaining just want to maximize my system for now and plan on a forged engine, and better heads later on.
Old 04-06-2020, 12:36 AM
Racetronix
Supporting Vendor
Racetronix's Avatar
Projected FWHP?
Please carefully read the details in this kit:
https://www.racetronix.biz/customkit...sp?kc=rfpk-052
Old 04-11-2020, 12:56 PM
frc00ny
frc00ny's Avatar
I get what you are saying. I was not saying that my parts are not adding up to what they should make.
I should have been more specific in my post. My first dyno session and tune was done many years ago with just the lingenfelter 255lph pump that came with the A and A procharger kit. The tuner stated then that I was running out of fuel at the top end. At that time it made 479 rwhp and 429 ftp of rwtq on 91 octane on the dyno
So years later I converted the fuel system over to a return style system with a boost referenced holley regulator, and installed the hotwire kit. But at the same time I added a boost friendly cam shaft, roller rockers, pushrods, 921 valve springs, kooks headers with catless 3 inch x pipe and 3 inch lg exhaust. This time it was tuned on 93 octane, as I moved back to NY from AZ. With the changes and octane improvement it made 532 rwhp and 479 ftlbs. I intend to push this little blower a bit more so I will need to add more fuel.
I should have asked my tuner whether he meant the injectors were maxed out or did he think it was fuel pressure or volume dropping off at the top end. I think the 340 lph pump would be better but I want to go even bigger than that so I wont be changing it out for a bigger one later.
To Dynoed the car today 730 whp p1sc!
Quick Reply: Dynoed the car today 730 whp p1sc!
