Weld RTS offsets for C5
I'm taking the plunge and going to get this heap hooking up like it should.
Car is a 02 Z06.
The rear has been mini tubbed and I'll be ordering my LG spindles here very soon. I am also installing C6 Z06 front brakes on the car.
I am wanting 15x10" Weld RTS for the rear and a pair of 18x9's for the front. I need to find out exactly what offsets I need so I can order these. Can anyone help???
Thanks,
Jarrod
Car is a 02 Z06.
Thanks,
Jarrod
Car is a 02 Z06.
Thanks,
Jarrod
Car is a 02 Z06.
Thanks,
Jarrod
I got mine in last week.On 10'' you only can use 7.5 back spacing.I ordered the 15x9.33 with 6.5 back spacing.Rts does not have a wheel with correct back spacing for you to use the mini tubbs.The most they have is 7.5 with a mid pad.
Received 1,762 Likes
Called them a few weeks back only have 15, 17, 18, with a 7.5inch back space only. I want a 16 rim with the correct offset so going back with a CCW dragpack for next yr.. Robert
I would buy weld RTS today if they had a 16"..... Because of their retardedness, I am stuck hunting for a CCW drag pack and have to deal with the weight penalty...
no changes yet.I had the spindles on at bg.just no wheels yet.The gearing is why I'm running 26'' slicks.I went 10.00 in and out throttle 4 times ay local track with a 1.69 60 foot.the one pass I got a good 60 foot on the intake pipe blowed off
My main concern is what offset to get the fronts in since I want a 18". Car was having a hard time stopping at TI last weekend.
O by the way..I did not gring calipers to make my rts fit.I grinded the top ball joint area when I ran the 16'' camaro the 1st time.15'' rts has more room then the 16'' camaro wheels do.
