ECS Black Friday SALE, S/C Kits, Fuel Systems, Pfadt, Mantic Clutches..ECT
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
We are going to be running this sale from 10PM on Thanksgiving untill Sunday night at Midnight. If you are interested please send me an email with ECS Black Friday Sale as the subject line during the times of this sale..
Please include the products you wish to purchase, your contact information as well as Car info and I will call you for payment. Thanks and any questions you can either post in the thread or send me an email...
Chris@eastcoastsupercharging.com
We are also offering FREE shipping in the Continental US on all sale items
ECS Supercharger kits C5/C6 SL-1500 Head unit.. $5,099
We can Install here for $2099
Kits come with the following
SL-1500 Paxton Head unit Self contained
All Steel Idlers
60 Lb Motron injectors
ECS Boost a pump
NGK TR-6 Spark Plugs
160 Degree thermostat
ECS Crank Pin Kit
ECS Catch Can
ECS Valve Cover breather
We will also include a start up tune
All ECS Trans Braces $349
ECS Complete Fuel Systems
Stage 1 (to 750-775 rwhp) $1199
Stage 2 (800-1000 rwhp) $1699
All Pfadt Products take 15% off their website prices expect the Johnny O' Connel package part number 1150028 and the newly released Headers.
Mantic Clutches... With the purchase of a clutch we are going to include our custom ECS Bleeder Kits as well as a new Pilot bearing
Single kit is $755
Twin kit is $1638
The twin clutch does come with a throw out bearing and slave cylinder and the single kit comes with a throw out bearing.
ECS Torque Tamers $159
Cam install Special $2799
Includes the following
ECS Custom Cam
PRC Dual Springs
Melling Pump
C5R Timing chain
Timing cover gasket
Front Seal
Crank Bolt
160 Degree Stat
Hardened Pushrods
NGK Spark Plugs
Under Drive Balancer
both belts
Full install and Tune
If there are any products that you are looking for just send me an email and I will let you know what we can do!!!
All Steel Idlers
ECS Boost a pump
ECS Crank Pin Kit
ECS Catch Can
Single kit is $755
Twin kit is $1638
ECS Custom Cam
PRC Dual Springs
Melling Pump
C5R Timing chain
Timing cover gasket
Front Seal
Crank Bolt
160 Degree Stat
Hardened Pushrods
NGK Spark Plugs
both belts
Bolts up to the last couple holes of the tunnel plate frame work & supports the torque tube from flexing upwards under acceleration.
I think it's a great mod, been using it from day one.
http://www.eastcoastsupercharging.co...ategory_id=174
Received 1,762 Likes
was referred to you for help
i am having a hard time with my tuner and i was hoping that someone in this forum may see something in my tune that may lead to the problem i am having...
first off mods
cam
headers
v-2 vortech charger
60lbs injectors
think that is all that is relevant
i am getting a 1514 code when under partial boost seems to happen when i am in like 3rd gear and give it around 3/4 throttle so it has time to build boost? as in 1st and 2nd under 3/4 throttle seems to reach 6k rpm pretty quick . but anyway 3rd gear 3/4 throttle triggers limp mode and 1514 along with 1278 under full throttle it doesnt seem to happen tuner says i must have electrical problems cuz he says he set everything to as high as it will go.
can someone with experience plz look at my tune from hp tuners and see if you notice anything that may cuz my issue???
first off mods
cam
headers
v-2 vortech charger
60lbs injectors
i did that is when mrr23 told me to get ahold of chris so i looked him up and tried to pm him and was unable to attach a file in the pm so this was the closest way i could think of to get ahold of him
