Tial wastegate springs ????
Wondering which springs to put in my wastegates to up the boost to around 18lbs. Currently at 14lbs at 750hp. I have the HPP twin turbo kit with the tial wastegates. And would it be safe to run 18lbs without lifting the heads?? I have a 408 stroker with 317 heads.
Hey,
I was considering doing this mod with the Tail 44mm WG. Maybe you could share your experience. Did you go with a smaller pulley to improve the mid range then bleed of overboost. Did it makea big difference in your mid range? Any problems with the reliability of the WG? If the WG does not open you can Blow your motor.
