Slow Rides twin turbo
Cruising
Get back to work! Can't wait to see the car when I take the family back to Iowa to visit in a couple weeks. Think it'll be running by then (and the snow melted?)??
Damn you Dave for bumping this Lots done with a few set backs, I'll ge some pictures this weekend if possible. Finishing gate/exhaust. Work, part time school and being lazy takes its toll haha
Slow ride things are looking extremely nice. The best part of your system is the fact that it is all V-Band system so no bolts backing out and easy way to install and uninstall the down pipes. I can't wait to see the final result. Now I am thinking of putting my system into Vband
Yea, v-bands are nice except on the wallet I just hope the gate setup can control boost well with the 38's. I ended up using a c6z 3" H pipe I modified since it was cheap and already made up and had to tweak the hell out of my LG big 3 to get it around the diff cooler crap. Keeping the exhaust tips lined up since the muffler pipes were fully welded in the past was a nightmare. Lots of cutting and tweaking.
Once I figure out a fuel pump issue I have I can start it without the lower IC pipes (haven't started them yet) and check for leaks, etc. Might get some motovation back after starting it I hope.
Yea, v-bands are nice except on the wallet I just hope the gate setup can control boost well with the 38's. I ended up using a c6z 3" H pipe I modified since it was cheap and already made up and had to tweak the hell out of my LG big 3 to get it around the diff cooler crap. Keeping the exhaust tips lined up since the muffler pipes were fully in the past was a nightmare. Lots of cutting and tweaking.
#33
Thanks, they are 62-1 compressor wheels (~65lb), but in a b cover (same front cover as the ttix turbonetics turbos). Turbonetics says using a b cover will cost you 5-10%, but without actual measurments who knows for sure. They might be able to crack 1000whp maxed out on a vette out a perfect world, but I'm sure things like backpressure, intake track, etc will come into play. Coming from a 500whp NA 383 I'm sure I'll notice the difference though
#35
I was going to do it kind of like the pictures in your upgrade post. I'm all ears if you have any better ideas or suggestions? I don't really like the tubing going through the sway bar and chaffing against things, but there is not a lot of room as you know. I run 285's in front so the tires are wide and I know I'll need room to fit them at full lock.
#36
I am thinking of 3 different options.
(1)Run the hoses under the air to air cooler into the nose like lingenfelter does,
(2) fabricate some metal inlets similar to how the TTI satge 1 kits were routed but there may not be enough room for large enough diameter piping.
(3) Run some piping into the fender cove area for shorter routing and cool air.
#37
That's good info. I wish I would have used the hose that vrybad posted in your upgrade thread as I think the rubber based product would flex easier and take abraision better. I used nice flexfab 2.75" double wall silicone that is strong and can even handle boost, but it's easy to rub through the silicone jacket on the outer wire reinforcement. I'm buying some rubber DR tape to wrap the rub spots as vrybad mentioned in a pm. I'm thinking about making some metal 3"inlets that pass between the rad/support like yours, but also mod the bracket so the pipe doesn't have to crush down any. I would then try to mount larger filters under the headlight.
It's hard to get the inlets on and off my setup so I'm not sure if I feel like changing the short section of hose that passes through the cradle, but I can run metal right after that point. Lots of things to think about on this one. I guess I saved the best part for last
#38
#39
Thats a good point about the spacers also. I think it's ok for now as I had to shave the heck out of my cradle in those spots, but if I switched to full 3" flex hose with a E cover compressors and a c6 oil pan I'd probably want to space it for sure.
Did you end up using a timer relay on the scavenge pump? I've looked at a few different options, but just curious to which one others went with. How is oil control with the scavenge pump? Do you get any smoking at all under load or light throttle, etc?
