Which Fuel pump combo under 650rwhp?
I will be looking to Push my P1SC combo in the neighborhood of 600rwhp.
I have already got a KB Boost a Pump and 60lb injectors. Which Fuel pump would be the best to pair with it?
Aeromotive?
http://aeromotiveinc.com/products-pa...-fuel-pump-gm/
Technically I do not see the C5 in the applications guide but my tuner can fabricate very well.
Aeromotive?
Received 1,762 Likes
ttt
I will have a A/A full system that sells for 1100.00 plus shipping for 600.00 firm plus true shipping. Robert
I'll look into them.
I will also keep this in mind. Thanks!
Several ways to do it.... the lesser expensive route.... the middle routes... and then theres the do it once setup. I had an intank 255 racetronix kit... on 93 octane and 60lb injectors... I was out of fuel @5500 rpms and almost 800wheel hp...kind of a cheap, easy investment, well within site of what you want. Just some food for thought. No BAP.
I would always go overkill on the fuel system.... more fuel=more power. Not only that.... maybe you'll want to add more power down the road...do it once, save your money.
Very true however I don't see myself pushing 700+ anytime soon. I will want to forge at that point and will be spending thousands on proper rotating assemblys etc.
For now I may go with a very good flowing intank with BAP just in case then down the road go to a twin pump or fuel cell and A1000 type of system. I know the fuel systems to support High HP are not cheap. I just need a safe system to support up to 650 wheel. My goal is 550-600.
Location: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
I ran a LPE pump for years with no BAP, with meth. Went 9.70's with it. Was still working perfectly when removed.
Looks like they run about $200 from Lingenfelter and they recommend a Boost a Pump for over 600 hp.
Again I already have a Kenne Bell Boost-A-Pump =)
Also is the walboro 400 a direct drop in with higher capacity than the 255?
Lingenfelter http://www.lingenfelter.com/mm5/merc...Store_Code=LPE
vs
Racetronix http://www.racetronix.biz/itemdesc.a...%2D005&eq=&Tp=
Both seem to be similar pump and price. which one is better?
vs
When I installed my ECS kit it ran on 60lb injectors with a stock fuel pump, BAP and Meth. Made 598whp on their dynapack setup. Knowing I wanted more power with the new forged motor. I went with 80lb injectors and a Walbro drop in 400lph pump, keeping the BAP & Meth as well. That setup will be power limited by the fuel rail and line.
I would suggest upgrading your in tank pump with the Racetronix setup or Walbro 400lph pump. A factory LS7 pump is also an option from prior research I did.
Supporting Vendor
Aeromotive?
Aeromotive?
Former Vendor
vs
vs
