60 lb injectors, built fuel system (w/ rtn) are they too small for E85?
I have a question.
99 LS1, P1-SC, heads/cam/header, meth/water inj. 12 psi (max) boost, 600 rwhp.
Fuel system is 'built' with in-tank walbro 340 feeding a GSL-392 pump.
This has the early style fuel lines with return (vs. dead-head).
Ive been told that the theoretical limit an injector can supply is the lb/hr rating *20.
So with 60 lb/hr injectors, that should mean they can support 1200 HP (100% duty cycle which you would never want to do).
So....these are big enough for my 'modest' 600rwhp car, on E85?
