Maggie cooling issues* RESOLVED* WOOT!....updated
Ok, I have a Dewitts radiator and the SPAL fans and the car still gets hot with the AC running....it did this with the old motor and the now with the new motor.....if I turn on the AC on a warm/hot day I can watch the temps keep rising even when cruising at 55...its fkin ridiculous that I can not keep this car cool. I watched it climb to 240 today before I shut off the AC and watched the temps drop down to normal.
My question is where is your intercooler mounted? Mine was installed down front before the AC condenser and the radiator which IMO is the issue...my car is lowered (basically sits 4 inches off the ground in front)
without the AC running the car is perfect.
My only thoughts are with the intercooler positioned where it is there is not enough space for adequate air flow combined with sitting so low and the hot air off the pavement.
considering moving the intercooler to open up that area
so I am open to suggestions
I assume your running duel fans, are you positive your second fan is kicking on with the AC switch? My intercooler is in the same location and never a issue.
Ordered a radiator off of here from someone a couple of years back. Max cool, stay cool, something like that on the name. Don't remember. I questioned him several times about how big it was. When it got here I didn't have to ask any more. Had to raise the front end of the car up and get a two inch drop from A&A to get it to sit right. I have my fans running off the ignition switch. Wired them in straight to come on when you turn the key on . They stay on all the time, and I have a 160 in there. I"m back up to stock height on the car. Had it dropped but the radiator won't allow me to do that any more and its hit the 200s before after playing with some friends on the curves but she drops right back down .
I'd check the second fan like gunnerja said and that one really nice c6 you have gunnerja .
YA,, your way over what you should be running.
Only other thing I can think of is you have a air pocket or are you sure your radiator is not clogged some.
Dead heat of summer we all sneak a little antifreeze in the race cars when we're not suppose to but changing it over or back and forth is a time thing. Gone the whole nine yards on that to with the bleeder line over top the motor and that didn't help. . Had a issue sent the electric pump back to the factory and they put a bleeder in the pump itself. Now I don't have any more issues but it was air pockets. I could watch the temps jump 20 and 30 degree then fall when the water started moving again, Hoping that ended my problem with that car.
One of my kids had a similar problem when he lowered his......turns out he left the air dam off.....no one could figure out why it would run hot even down the highway.... then I saw the air dam on a shelf in my garage one day.......yours' still on? Ya I know, but thought I'd mention it anyway.....
Supporting Vendor
You might try temporarily spacing the condenser forward an inch if you have the space to do it to see if it helps. Try spacing it at least at the bottom. I'm not a big advocate of having any significant space between the radiator and condenser. With the increased thickness of the Dewitts, you lose that space.
I'm assuming you still have your full shroud in place too.
I run a huge oil cooler to help remove heat that way.
The last thing that I did in my quest to cool my car down was run the WP319 Meziere water pump. Dropped my temps 15° in stop and go traffic, although I understand your issue seems to be at speed.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
full shroud
I suppose an oil cooler is an option
my issue is ONLY with the AC running....sitting it creeps up and moving doesn't seem to help unless I can get a clear stretch of road with no one in front of me for quite a distance but in late afternoon or moderate traffic thats just not possible
without the AC it doesn't matter the car maintains temp with no issues
ONE LAST RESORT if that don't work. Get a tiger shark front end.
Just picking and I feel for you cause that would drive me crazy to.
All I know to do is hot the fans to come on when the car is on and what the others have mentioned.
I have a kit from a vendor on here RSD, you need to relocate the battery to the trunk, and if you check it out here
http://www.racespecialtydesigns.com/...&cat=33&page=1
Maybe send him a pm and get him involved in this post,
I can`t say how much it changed my IAT`s, but removing a heat source from in front of the rad helps a lot, my coolant temps are running cooler, and I was suffering from the same problem.
it may come to that
alright, my IC sits at about a 90° angle to the radiator in the air scoop opening (roughly a 45° angle leaning forward towards the front of the car).
I can only give you advise of my setup I'm selling right now. Have you checked you intercooler pump? Mine was running a bit weak so heintz racing diagnosed the problem and resolved it. Also my intercooler is mounted in front of condenser on the radiator support. Basically the first thing that gets any air. Let me know if this doesn't fix it and I can run it by the guys. There very helpful anytime I ask.
I looked at buying a separate fan and relocating the IC somewhere much like the idea posted above
maybe this is me just thinking out loud here, but wouldn't you want to avoid putting all the heat exchangers right on top of each other? i'd imagine that transfers a lot more heat-soak between them & makes each of them less efficient.
Today is the day
yeah I know this is an old thread but today I am going to start on this project.....gonna pull the front bumper/fascia and see about moving the heat exchanger up behind the license plate area and opening it up ala ricer style.... I will install a screen over the opening and if this doesn't work I can cover up the hole with the filler plate and try something new...
I will try and take some pics as I go....
well the front end is off and the the heat exchanger is out....no debris up there....going to buy a few parts to fab up a new bracket and extend the hoses...the fins weren't even clogged so I can only assume it was a free space issue.....time will tell
where can I buy a filler plate with mesh in it or do I have to make my own?
hope I can get this all back together
