Balancer Bolt Torque
Hi,
When tightening the bolt after pinning the crank and balancer, what is the best way to hit the required torque? If I try to torque by hand, it just spins. I used a 300ft/lb impact gun and tightened it down until it would not move any more plus an addition 5 seconds...wondering if I got it tight enough...anyone have thoughts or suggestions?
Thanks!
Thanks!
Stephen Stewart (04-06-2022)
That might work. Just keep an eye on it during the first few hours of operation, making sure the belts stay aligned. Especially pay attention to the A/C belt.
I got the flywheel holding tool. Sooo handy! Search ebay for J-42386-A
Hi,
Thanks!
Thanks!
The real reason the balancer/bolt comes loose is because of slight rotational movement between the crank and the balancer, pinning stops this.
ISIS SUCKS FAT CHOAD
Here's my experience. I put a crank bolt new factory bolt in my first vette after a head and cam swap. used a breaker bar and went as tight as I could get it. Well as it would turn out I should have followed the manufacturers specs. The damn crank pulley walked off the front of the crank shaft right into the steering rack at highway speeds. Fortunately I didn't damage anything just cosmetic damage to the rack.
My suggestion do it right just as GM recommends then you can be certain.
