New LS Timing Cover Alignment Tool! Check it out!
Supporting Vendor
AlignIt Timing Cover/Crank Seal Alignment tool
Here is a simple but very effective tool to help you make easy work of installing your LS1-2-3-6-7-9 timing cover and seal.
The Alignit tool gets the timing cover centered perfectly with the crank and installs the seal in seconds!
Having the seal centered accurately with the crank minimizes the chance of seal leakage. Only $19.95
http://www.saccitycorvette.com/Timin...nmenttool.html
Update! We made a improvement to the AlignIt!
We will have to add a a few bucks to the cost. The New price
will be $26.95.
We will keep the $19.95 price through the Memorial weekend.
After that we will implement the new price.
Also if you purchased a AlignIt without the O-Ring and you would like a O-Ring installed at no charge just send it back to us.
Basically the O-Ring lets the AlignIt fit snugger in the cover holding it in place better.
One other thing, we are working on a Rear Main AlignIt tool.
Here is a video that shows how simple it is to use.
will be $26.95.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Supporting Vendor
Inexpensive way to insure proper alignment of your LS timing cover. Also makes seal installation a breeze!
Supporting Vendor
Sorry, just added a link. And it on our website under LS1-2-3-6-7-9
Supporting Vendor
A little RTV in the corners where the timing cover and pan meet.
I don't think you need anything on the seal.
You should double check that.
Christian
Supporting Vendor
Supporting Vendor
Want to do a forged motor soon as,that tool can only help,even if i only use it a few times.
Simple,and brilliant.
Any chance you could ship to a limey in the uk ? USPS works well
Cheers Nitro
Supporting Vendor
Sure, go ahead and order and we will get it out to you.We will let you know if there is additional shipping charges.
We are always trying to improve our products and we have made a improvement that will add about $7 to the cost. If you order now before our website is updated you can still get it for $19.95 I will post a updated picture.
Thank you,
Christian
