*Here's a great way to protect your lower radiator support/skid plates!*
Old 06-06-2013, 04:20 PM
SacCityCorvette
Supporting Vendor
SacCityCorvette's Avatar
Location: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default *Here's a great way to protect your lower radiator support/skid plates!*
Hi Everyone!
C5/C6/ C7 Corvette owners know that the front skid plates are vulnerable to getting bumped and scraped. Fangs from SacCityCorvette provide the best possible protection available for your front skid Plates/Lower Radiator support on your C5/C6 / C7 Corvette. Made of a High Impact Superior Performance Plastic, the C5/C6/ C7 Fangs are extremely impact resistant and 6 times more abrasion resistant than steel and Installation only takes a few minutes. Being only 1/8" thick you will not even notice any clearance loss. There is NO drilling or modification required! C5 Fangs are a simple 10 minute bolt on using your factory bolts.C6, you simply glue them on or if you prefer, they can be screwed if you order the screw on kit. It comes with drill bit and tapping screws. Once the Fangs are installed you will have the best protection available. $49.99 is a very small price to pay for such good protection of such an expensive part of your Vette!
(Note: we still have the screw on C6 Fangs for those who prefer them. Check our website)
Some of the Benefits
1) They are only 1/8” thick so there is no noticeable ground clearance loss. That’s very important since there is not much clearance there to begin with!
2)The superior performance plastic we use is 6 times more abrasion resistant than steel making them slide very smoothly over what ever they come into contact with.
3)They perform perfectly in hot or cold weather.
4) They distribute the load over the entire skid plate where it is the strongest and can evenly distributes the impact, not on one side or the other where the side load can bend skid plate.
5)There are no moving parts to wear out.
6)They only weigh 5oz for those that worry about weight.
7)There is no drilling or modification needed to install them
8)The Fangs give protection over the entire skid plate. So if you bump up on a parking block like we demonstrate in our video you are protected from the front to back and from the highest point of the skid plate to the lowest.
9)They look like something that came on your Vette from the factory.
Here is a video of the Fangs getting used!
http://www.saccitycorvette.com/See-t...n-Action-.html
Here is info for the C5 Fangs
http://www.saccitycorvette.com/Fangs.html
Info for the C6 Fangs (Note: we still have the Screw on C6 Fangs for those who prefer them. Check our website)
http://www.saccitycorvette.com/C6-Fangs.html
Info for the C7 Fangs $66.95
http://www.saccitycorvette.com/C7Fangs.html
C6 Glue Fangs
C6 Screw On Fangs
Fangs will help prevent this from happening.
No gluing for the C5 Fangs. They bolt on with factory bolts.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 06-25-2013, 07:12 PM
SacCityCorvette
Supporting Vendor
Have you looked at your skid plates lately?
Old 08-07-2013, 07:24 PM
SacCityCorvette
Supporting Vendor
Had a customer tell me that Fangs are "preventive maintenance". Thats a good way to put it. He said it as in changing your oil before you spin a rod bearing.
To Protect your lower radiator support before its gets beat up and broken.
Matt
Old 08-26-2013, 02:09 PM
SacCityCorvette
Supporting Vendor
We offer many more of the top name brand products then we have advertised on the forum and our website. Email or pm us with what your looking for and we will be glad to get back to you with quotes and do our best to save you $$$.
Thanks,
Matthew
Old 03-07-2014, 05:15 PM
SacCityCorvette
Supporting Vendor
Vette season is almost here!
Old 08-05-2014, 01:13 PM
SacCityCorvette
Supporting Vendor
The C6 lower radiator support is aluminum so its especially fragile.
Old 08-26-2014, 08:13 PM
SacCityCorvette
Supporting Vendor
Did you know: The name "Corvette" was borrowed from a line of small, fast navy ships used in World War II.
Old 08-29-2014, 05:00 PM
SacCityCorvette
Supporting Vendor
The first generation Corvette was introduced late in the 1953 model year. Originally designed as a show car for the 1953 Motorama display at the New York Auto Show, it generated enough interest to induce GM to make a production version to sell to the public. First production was on June 30, 1953.
Old 09-04-2014, 12:36 AM
SacCityCorvette
Supporting Vendor
The second generation (C2) Corvette, which introduced Sting Ray to the model, continued with fiberglass body panels, and overall, was smaller than the first generation. The C2 was later referred to as mid-years.[19] The car was designed by Larry Shinoda with major inspiration from a previous concept design called the "Q Corvette," which was created by Peter Brock and Chuck Pohlmann under the styling direction of Bill Mitchell.
Old 09-05-2014, 01:32 PM
SacCityCorvette
Supporting Vendor
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9 Timing and Rear Main cover and seals.
The AlignIt tool gets the timing & rear main covers centered perfectly with the crank and installs the seal in seconds! Check out the videos.
Having the seal centered accurately with the crank minimizes the chance of seal leakage.
Timing Cover AlignIt Only $26.95
Rear Main AlignIt Only $37.95
Hub simulator only $23.95
Buy more than one of the AlignIt Tools and save!
http://www.saccitycorvette.com/Timin...nmenttool.html
Old 02-19-2015, 01:55 AM
SacCityCorvette
Supporting Vendor
SAME DAY SHIPPING!!!
Old 03-15-2015, 03:12 PM
fsuforever
fsuforever's Avatar
I've had to replace 1 radiator support & from the added weight from the iron block ,I found these work real well for me /A&A wheel/potholes dips in the road .this Is the first thing that hits the road
Old 03-18-2015, 01:03 AM
SacCityCorvette
Supporting Vendor
fsuforever
Old 06-13-2017, 07:19 PM
SacCityCorvette
Supporting Vendor
Fangs from SacCityCorvette provide the best possible protection available for your front skid Plates/Lower Radiator support on your C5/C6/C7 Corvette.
To *Here's a great way to protect your lower radiator support/skid plates!*
Quick Reply: *Here's a great way to protect your lower radiator support/skid plates!*
