WARNING if using Proform LS valve covers!
It's doing OK. Still working my way back up to 20+#. Leery after the last meltdown. The lower compression and bigger snails seem to spool slower. Not noticable most of the time but I used to be able to do a 3rd gear brake boosting 60 roll and have it launch really well before but now it lags. Need to start in 2nd and quick shift to third and even then it loses boost in between shifts. Still getting it sorted.
http://store.katechengines.com/msd-s...wires-p41.aspx
i know this is an old thread but can anyone tell me how you drilled out the tube, I have a set i'm wanting to this do this as well but i can't figure out how you drilled it out, can you remove the tube???
Oh yea, here's a pro tip on the wires: Katech. Best around and happen to be the cheapest.
i had them now i got ultra 40s bad ***
Yea twist it and it'll pull out. Then it ~presses back in (by hand).
#34
can you just thread that hole and then use a female NPT to female AN fitting?
#35
#36
I don't remember exactly what clearances were under there, but I don't think it would be as easy as just tapping large enough for say a -10AN bung off of it. The baffles underneath it are very close, so you would have to cut down the NPT thread length a bit to not smash into the baffle.
#37
I drilled out the holes I pulled the elbows from with a 1/2" drill and had -10 male fittings welded to the angled faces directly over the holes. Looks good and now I can attach my braided -10 lines to the vc's.
#38
yea, I just pulled the stock fittings, but one broke, so I had to drill it out....looks like the stock hole size was 3/8, but I think I wallowed the one out a bit, so Im going to drop them at the local machine shop tomorrow and have them drilled to 1/2 and try a 1/2 NPT to 6 AN fitting that should work nicely with my breather that came with 6 AN fittings....or I may have just ruined one of the two valve covers....we'll see
#40
so the issue isn't so much tapping the hole to accept an NPT to AN fitting, its the fact that the relief in the valve cover around the hole isn't big enough to allow even a 3/8 to 4AN fitting. Since theres an internal baffle, I may just find a straight barbed fitting that I can mount one of those small breather style K&N filters and vent it right to the atmosphere.
