WARNING if using Proform LS valve covers!
I recently had the baffles off to install a couple -10AN fittings to mine for crankcase ventilation. The covers have a 3/8" hose connection already on them from Proform. So you would assume it's the same on the inside under the baffle, right?.... WRONG.
It's smaller than 1/8" pinhole on the inside. If you're running these covers and using the vent tubes, or plan to, then I strongly recommend you make some changes before you start pushing seals out.
There are a few indirect photos of them on mine in here:
http://forums.corvetteforum.com/c5-f...5-lives-3.html
No leaks so far. They have a rubber washer to seal to the bolts.
I didn't use the coil brackets. Mounted the coils in the fenders instead.
I run those. Thanks for the tip. I run the drivers side nipple with 3/8 hose to atmosphere but I also have a breather on the oil fill hole with a 5/8 hose. Both run to the back of the car.
I do like these covers.
ISIS SUCKS FAT CHOAD
They look like nice covers. Easy fix for the 3/8 nipple to the pin hole size under the cover. Definitely glad you pointed it out for other who may not pay attention. How much are the covers?
I want to say mine were ~$425 with the coil brackets. They're similar look and quality to Katechs which are ~$400 but their coil brackets are another ~$200.
Received 1,762 Likes
Regarding the PROFORM LS valve covers...only the driver side cover (PCV) has the swaged tip. The passenger side tube is wide open. Lots of internal clearance inside for big rocker setups.
