A&A D1SC install and lots of other stuff!! Pics soon
#363
Received 1,261 Likes
none of us do that... jk, if you're interested in a meth kit look into alky control... most of us use the washer fluid tank but you can also add a separate tank if you choose to
#366
depending on how heavy your relying on meth you could gain around 40hp by switching. that seems to be the average on switching,
#367
Thanks gents!!! It's coming along a lot slower then what I want but it is what it is. I'm actually going to take Tuesday off to do some work but I had a few hours to spare over the week so I was able to change out the rear seals..
I took the rear diff completely off I didn't have to I just wanted to..i didn't know there was a bolt on the bottom so I was like a monkey ****ing a football trying to get it to separate from the tranny. yeah I'm a idiot..
I went from tapping the stud to banging it before I realized there was a bolt on the bottom so I jacked up the stud but I grinded it down so all is good..
I thought this looked cool/
old seals out new going in and wtf are those wheel looking things? They seem to serve no pupose. They are bolted to the rear diff but that's it nothing else. Why are they there?
all sealed up
New fuel system coming I jacked up the feed line so I have someone making me something. That mishap cost me a few hundred because I wanted to go -an fittings from the tank to rails.. I also got my 3.7 pulley once I get my fuel fitting I will start the drivetrain install. I want to leave it out since I have room to sit underneath and run my lines right.
all sealed up
#370
had a little time to work on it. I went with a 3.7" pulley my previous was 3.85 so this should net me another 1.5lbs of boost. Should break into the 700s
Mounted with belt loose.
My catch cans fittings were loose didn't realize how much oil has been spraying. My condenser and fmic is caked with oil..
Started on the pilot bearing install. Took me a few whacks and it went in. I should of heated it a little more to make it easier..
here it is installed I hope I didn't mess it up but I just hit the chamfered side but it's flush. I also prepped for the rear main seal cover. I used 220 grit and some degreaser. I'm gonna grab some copper spray to insure a nice seal..
I'm gonna try to get the flywheel and bellhousing and clutch in tomorrow. I took a day off of work so I can just focus and getting it back together.
#371
Got some work done today so hopefully those fitting come in so I can get the drivetrain back in. It's just easier to work underneath while it's out.
I didn't have a flywheel tool so just used this..
All torqued down
Inside the bellhousing before and after
Bellhousing mounted with 2 bolts in. I cant find my swivel and damn you need small hands to even get them in there. Honestly this was the hardest part of this whole ordeal. I spent an hour trying to get 2 bolts in and after awhile I just said **** this I'm done I was getting frustrated since I couldn't find the swivel so Ill just hit harbor freight and grab a set.
I'm trying to stay organized this time been labeling things as I go..
Ill start running fuel lines and putting the headers and engine stuff back together
All torqued down
#372
I love those saccity alignment tools, they make it super easy to align the covers... I'm sure the oil leaking inside the bellhousing wasn't helping your old clutch on top of the power you are making... new clutch looks real nice though... what exactly are you doing with your fuel lines and did you ever get the pressure drop issue fixed??
#373
Trying to hit the 700+club with Neutron and I huh Shant?
My clutch install was easy this time
#374
m trying hopefully the block lasts..WHat cooling system are you using? I'm still on the stocker and want to upgrade eventually
#375
Yes sir. I'm still on stock cooling system with 160 T stat. I did open up the rear steam vents as well with a cross over. Car is running about 190 collant temp and 210 oil temp so i think its well in the acceptable range. Ive had it up to around 200 coolant and 224 oil but thats no hotter than the stock cars run on hot summer days so i think it's ok. I just keep an eye on it.
#377
Instead of using all those items like Matt did i used the GM truck cross over mentioned down the page on post 11. GM part #12605716.
All you have to do at that point is either run the lines like Matt did or what I did was run the cross over rear then have a hose around the rear of motor and come up to front to meet the line from the ls6 cross over on the front before going into the radiator.
Does that make sense?
Basically run factory cross over tube in front and truck cross over in rear to open all vents and T them together before going into radiator.
#378
Cool Ill check it out in awhile. Taking a break me and the top bellhousing bolt arent seeing eye to eye and I just broke a spark plug and the coolant temp sensor so I figured I need to step away for a bit..
#379
Got some work done yesterday and it me a loooooong time to get that top bellhousing bolt in. My dumbass couldnt find it because of the wiring harness but I finally got it in..I got the pulley on, bracket and a few other things. All I need are a few more fittings which I seem to never stop ordering but I should be done by next week.
I rerouted my return so it goes straight into the return line in the tank. I used some wires to fish it through the stock route
I started adding my feed fittings. Someone is making me -8an fittings for teh feed so I can keep that siphoning from the passenger side tank.
These add up quick..I had to order a few more today
Since I was manhandling the driver side header I jacked up all the titanium wrap..That was a waste of money. I also broke 2 spark plugs and the temp sensor..I also took the stock line out..It's gone
I redid my ricer lights
#380
