A&A D1SC install and lots of other stuff!! Pics soon
#462
ahhh gotcha..yeah Ill see if this bugs me enough to move it. I wouldn't mind having something like that right on the steering column so I can view it better. Hard enough to read the other gauges once you get into in..
#466
https://www.dynotunenitrous.com/stor...?idproduct=387
Well finished it up this week and I don't like the placement so I bought a 3 pod pillar from Carl...Thanks again man!!!and will use that until I switch gauges later down the road to some type of warning system so I dont have to try to look at the road and gauges and shift and look for cops, etc etc..
everything was working great and I got the car out for about 30 mins and then the car just had to power and had a weird noise. I limped it home and opened the hood and found my bov line has split in half or melted in half. That was my bad I forgot to move the line back to where I had it before and I literally had it next to the header. another ooops on my part. I will mess with it later this week
I also found my elm adapter and using the torque app to data log. I forgot I had it laying around.
and here is pretty is..yes I know my line lock button is crooked this was just a quick pic. Ill have to get that bezel redone...that wire that you can see isn't visible now. its the cable to attach for logging. I just tucked it in the cup
#472
Found a leak in the upper pan gasket right where that bolt is by the starter where it meets the block. So I get to pull the front suspension first before tune..Of course that would happen a few days before I drop teh car off....grrrrr ...oh well it's life
#473
Received 1,261 Likes
how bad is the leak?... if it isn't bad just get that sucker tuned first and fix the oil leak afterwards
#476
hmm that's quite a bit in my opinion, I would probably fix that first then... curious to see where you end up... I took mine to a dyno day this past saturday and when I got there it was all booked up so kinda a waste of time, I'll just go back and pay normal price on a day that no one else is there
#477
#479
Not much to update my GVR4 got hit by some ladie that decided to run a red light so they totaled it out it wasnt a massive crash but just enought to where they would total it out... There arent to many on the road so I was pretty pissed but oh well. I havent fixed the leak on the vette and the wideband already took a dump on me so it's just sitting waiting for me.
I picked this up as a DD but Ill get back on the vette in a few weeks or later in teh winter. Not much of a hurry now..
04 wrangler completely stock except for stereo and heated seats. Just ordered some wheels/tires and a 4" lift it should be here later this week..here it is in stock form
