McLeod Twin Disc Clutches on Sale! In Stock
Former Vendor
Some of the NHRA PRO STOCK cars use Mcloed.
We've been using McLeod Twin Disc Clutches for years with great results. They hold big power, are priced very well, and provide a lighter than stock clutch pedal for the ultimate in driveability!
$720 shipped - McLeod RST Street Twin Disc Clutch
$900 shipped - McLeod RXT Street Twin Disc Clutch
$319 shipped - McLeod Steel Billet Flywheel
$471 shipped - McLeod Aluminum Billet Flywheel
Intended for the high horsepower street fan, the RST & RXT Street Twin Clutch Kit is an economically priced twin disc clutch that can handle 800HP (RST) - 1000HP (RXT). This clutch kit can handle almost any horse-power you can throw at it and still remain street driveable. Organic (RST) & Metallic (RXT) lined clutch discs will provide smooth engagement with a soft pedal effort to make this clutch kit ideal for the street performance enthusiast.
Application:
LS1, LS2, LS3, LS6, LS7
Features:
-Handles up to 800HP (RST) - 1000HP (RXT)
-Supplied with alignment tool
-Lighter than stock pedal feel
-Bolts to stock factory flat flywheels (LS1/LS6 only)
-Easy Installation
-Organic (RST) & Metallic (RXT) facing for smooth & even engagement
-Smooth engagement with excellent release qualities
-Low Rotating Mass (moment of inertia) for quick revs
-Includes CNC machined and anodized flywheel adapter ring
-Blanchard ground floater with multiple straps to reduce noise for streetability
Application:
Features:
-Easy Installation
Cruising
I have 06 c6 stock at the moment. ...i will be super charging with meth next summer would this work for stock at up and also would the stock flywheel work worth this clutch
Application:
Features:
-Easy Installation
Application:
Features:
-Easy Installation
Former Vendor
These would be a great clutch setup for your build. Just pick a clutch that is suitable for your hp range and your good to go. It will require you to purchase a flywheel as well, but well worth the investment.
