High Torque Gear Reduction Starters! Very Cool!
Supporting Vendor
These new ProComp Pro Thunder High Torque Gear Reduction Starter Motors turn the engine over faster than any stock starters.
Producing between 30 - 40% more cranking power, these 100% Brand NEW starter motors also feature an offset design resulting in more clearance between the oil pan and the starter. These new Pro Thunder Starter is designed to crank over the highest compression engines on a hot day. They feature all new components beginning with a three horsepower motor, a reduction 4.4:1 gear set and a Anodized and Powder Coated assembly to protect and keep it looking good. The armature is balanced during assembly and is guided by two ball bearings for smooth engagement and thousands of starts The Pro Thunder High Torque Gear Reduction Starter also features a billet aluminum mounting block that can be positioned in different locations to help clear suspension parts, the oil pan and exhaust systems.
1 Year Warranty
If you have headers look at the measurement picture and see if you have enough clearance. We had one guy not have the nessesary clearance. He didn't know what brand the headers were. The starter DID clear our 1-7/8 Kooks Headers.
Because this starter takes 2 long bolts instead of one short and one long, we are supplying one long bolt with the starter to go with your exiting long bolt. We also rotate the starter for you to the same position that worked best on our engine. Also there is a small tab that is cast into the housing of the starter that touches the block. We are machining that off for you. It is one of those things that you wouldn't notice but it binds against the block when you tighten the bolts down. We found it because our engine was out when we installed it and had a good visual. We have been in contact with ProComp and they want to work with us to resolve it. Its a minor issue if you know its there and nothing you need to worry about because its taken care of when you receive your starter from us and in no way affects the warranty.
Added pictures below to answer some of the questions we are getting asked.
A quick word from SacCityCorvette.
We use one of these Pro Thunder high performance gear reduction starters in our high compression 444 cubic inch LS2 Stroker 02 Z06. It is awesome! It spins the engine over with ease! And you will love the way it sounds too! Its one of the notably best upgrades we have done! We highly recommend this starter for any LS series engine whether it is stock or a race engine.
Only $172.95
http://www.saccitycorvette.com/LSxStarter.html
We also carry OEM style starters. See below.
Here's what you get.
We have added the Pig Tail wire. It eliminates the need to modify your factory wire that screws on to the solenoid. Simply screw the pig tail and your factory wire together then use the shrink tube to insulate the connection. Then just plug the quick connect onto the new starter solenoid.
OEM style Starter $129.95
1 Year Warranty
Only $172.95
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Supporting Vendor
Look at this beautiful LS Engine starter. 3hp Motor, gear reduction 4.4:1 starter. Produces between 30-40% more cranking power than stock starters. The starter has a smaller body and a mounting block that can be rotated to clear oil pans and header assemblies, not to mention that the starter being small keeps the starter further away from the header effectively keeping the starter cooler.
^from ebay ad
^from ebay ad
Supporting Vendor
Hi SBCGENII,
It is the same starter without the long bolt or the modification we do.
Did you see the MSD one next to the ebay add your talking about for $240? Looks diffent paint and they even use the same write up with a couple name changes.
I updated our post so you can see what I mean.
Christian
Christian
Supporting Vendor
Supporting Vendor
On our 444ci 12.5:1 compression engine the stock starter turned the engine over and seemed fine, a little slow but always started. When the starter went bad we replaced it with the PC gear reduction starter. That is when we realized how much the stock starter was lacking on a performance engine. Even if I had to replace a starter on a stock Ls engine I would go with one of these starter.
Christian
Supporting Vendor
Sound clip from Mister Peebody using the ProComp high torque starter.
http://forums.corvetteforum.com/c5-g...ry-cool-3.html
Christian
Christian
Supporting Vendor
Supporting Vendor
Did you know: The name "Corvette" was borrowed from a line of small, fast navy ships used in World War II.
Supporting Vendor
The first generation Corvette was introduced late in the 1953 model year. Originally designed as a show car for the 1953 Motorama display at the New York Auto Show, it generated enough interest to induce GM to make a production version to sell to the public. First production was on June 30, 1953.
Supporting Vendor
The second generation (C2) Corvette, which introduced Sting Ray to the model, continued with fiberglass body panels, and overall, was smaller than the first generation. The C2 was later referred to as mid-years.[19] The car was designed by Larry Shinoda with major inspiration from a previous concept design called the "Q Corvette," which was created by Peter Brock and Chuck Pohlmann under the styling direction of Bill Mitchell.
Supporting Vendor
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9 Timing and Rear Main cover and seals.
The AlignIt tool gets the timing & rear main covers centered perfectly with the crank and installs the seal in seconds! Check out the videos.
Having the seal centered accurately with the crank minimizes the chance of seal leakage.
Timing Cover AlignIt Only $26.95
Rear Main AlignIt Only $37.95
Hub simulator only $23.95
Buy more than one of the AlignIt Tools and save!
http://www.saccitycorvette.com/Timin...nmenttool.html
