Custom FMIC and Vertical Radiator Results and Pics
Old 10-25-2013, 02:14 AM
LTstewy8
LTstewy8's Avatar
Default Custom FMIC and Vertical Radiator Results and Pics
Hey Guys,
I've been lazy getting this thread started, but I figured y'all would be interested in this setup that the guys at JTM Motorsports fabbed up for me. Needless to say, it's much more beautiful and daily driver friendly than the previous setup (procharger dual IC ground clearance w/ lowered cradle=). It also dropped water temps by about 10, although I still need to put my new oil cooler on.
The engine is a forged ls3 block (thanks Aaron @ Texas Speed) with an A&A D1sc bracket and some other goodies. I owe a lot of thanks to Josh @ A&A for going above and beyond- as well as countless other forum members and sponsors whose write ups and experience helped a ton over the course of the build.
Anyways, here are the pics of the custom FMIC & radiator. The real thing of beauty is the chromoly cradle John and Matt @ JTM dreamed up and fabbed up, which gives me ground clearance I never knew was possible even when stock. It even retains the factory A/C condenser, which is only apparent in the first couple of pics. All that new found space up front is just begging for a turbo. some day...
BTW, this whole build was just supposed to be a weekend cam swap about 1 year ago until I pulled the stock cam and found the lobes chewed up thanks to some quality ls1 lifter trays I presume So I dropped in a forged ls3 and an RPM level 6.5 4l60 along with everything else that goes along with that sort of thing, since that was the only reasonable thing to do. Then I got some AFR 225 heads from a forum member that I couldn't bring myself to mill down a bunch to an N/A compression ratio, so I threw the d1 procharger kit I got from a local forum member on there.
Then the flat bed tow truck who gave me a lift over to JTM for the start up tune managed to hook the factory radiator cradle, so the only reasonable thing to do was have them make this custom setup haha.
Here it is as it sits today. I'm trying to get to Atco this weekend to see what it runs. I'm sure I left out a bunch of info since I'm writing this at 2am, so let me know if you have any questions.
Old 10-25-2013, 06:27 AM
mobius
mobius's Avatar
Looks awesome!
Old 10-25-2013, 06:58 AM
madmatt9471
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
That is super slick - too bad they don't sell these!
Thanks,Matt
Old 10-25-2013, 06:59 AM
venomws7
venomws7's Avatar
Looks awesome I love it you can fit huge turbos now
exactly what I did...
Old 10-25-2013, 08:18 AM
chuntington101
chuntington101's Avatar
What are the dimensions of the new rad? Looks REALLY thick.
Someone really needs to sell these as a bolt on cooling solution. If they came with a new cradle and front crash beam it could almost be a bolt on solution!
Also whats the size of the inter-cooler?
Old 10-25-2013, 08:43 AM
JoeyG
JoeyG's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Very nice setup!
Old 10-25-2013, 08:55 AM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Thanks,Matt
looks like a very nice build you have yourself.Robert
Old 10-25-2013, 10:04 AM
LTstewy8
LTstewy8's Avatar
I agree It's a Griffin 26x16x3 radiator and there's enough room b/t the rails for a 28" wide rad looking at it. Intercooler is a CXRacing 24x12x4. It's definitely doing some favors for the D1sc with a huge 4.75" pulley to make the 8-9# being pushed through it w/ an air filter.
Old 10-25-2013, 10:27 AM
jmuck
jmuck's Avatar
Looks killer! I'm gonna have to steal that idea. Opens up a ton of room for an inlet on larger blowers.
Old 10-25-2013, 01:04 PM
a/c man
a/c man's Avatar
I like that. makes room!!
chuntington101
Is the rad single or double pass? I guess if you wanted more rad you could tilt it forward and run a taller rad. Someone really needs to come out with a kit for this!
Old 10-25-2013, 01:21 PM
tbrent
tbrent's Avatar
2018 C5 of Year Winner
Awesome setup!
Old 10-25-2013, 02:33 PM
nullpointer
nullpointer's Avatar
Awesome setup, wish they sold those
Old 10-25-2013, 06:11 PM
Robert 2000
Robert 2000's Avatar
That looks real nice frees up a whole lot of space.
Old 10-25-2013, 07:11 PM
Anti_Venom99
Anti_Venom99's Avatar
They need to sell this as a kit! Would make mounting my turbo MUCH easier!
Old 10-25-2013, 10:34 PM
JTMmotorsports
JTMmotorsports's Avatar
Thanks for the compliments guys, We were really happy with the way James' car came out!!! We would love to make more!!
John
JTM Motorsports
Old 10-25-2013, 10:52 PM
nyls1346
nyls1346's Avatar
Yup thanks, im real happy with how it came out james and hopefully u can make it to the track soon cause car is gonna move out
Matt
To Custom FMIC and Vertical Radiator Results and Pics
Old 10-25-2013, 11:12 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
MVP'S ZO6's Avatar
Cool setup brother!!!
How are the IAT's?
Old 10-27-2013, 12:03 AM
LTstewy8
LTstewy8's Avatar
I don't remember how the IAT's were, and I didn't have a data logger for my runs at Atco last night. I have a cheap scanner that I can go out and have a buddy check with on the street.
Matt, It's been a couple years since I've been to the drag strip, and my first time with 575rwhp so my skill was definitely the limiting factor. After some ugly passes, I finally got a 10.75 before the track closed, but I know I can do better.
Old 10-27-2013, 12:45 PM
JTMmotorsports
That's a bad-*** Street car right there!! What were the 60ft & MPH?
John
Quick Reply: Custom FMIC and Vertical Radiator Results and Pics
