FML: Think I've got that 7 cylinder model now
Old 10-31-2013, 11:07 AM
4DRUSH
4DRUSH's Avatar
Originally Posted by Lloyd Christmas
We put the fattest injector there too.
Coated diamond pistons
compstar rods
arp rod bolts
stock crank and block
ls6 cam
total seal rings
tsp ported ls6 oil pump
Rear steam/water lines connected ?
Old 10-31-2013, 11:14 AM
Lloyd Christmas
Lloyd Christmas's Avatar
AFAIK. LS6 manifold
Old 10-31-2013, 11:57 AM
SBCGENII
SBCGENII's Avatar
Not unless he bought some and installed them. I bet this was a fuel supply issue unless the tune was way off.
Old 10-31-2013, 12:07 PM
Apocolipse
Apocolipse's Avatar
Received 1,278 Likes on 923 Posts
Shouldn't race with low fluid. I never go below half tank.
Old 10-31-2013, 12:17 PM
Turbo-Geist
Turbo-Geist's Avatar
2017 C5 of Year Finalist
I knew I remembered this build from last year and some of the other discussions.
Do you remember this discussion? http://forums.corvetteforum.com/1581214837-post75.html
Did you ever add a methanol injection kit to the car?
Old 10-31-2013, 12:45 PM
Blow Torch
Blow Torch's Avatar
Unless you lost fuel, you should have damaged a forged motor at that power level
Really interested in finding out what happened
Old 10-31-2013, 01:16 PM
Robert 2000
Robert 2000's Avatar
Sorry to hear about the loss. I hope it can be fixxed and back on the road soon.
Old 10-31-2013, 04:12 PM
Turbo-Geist
I have noticed on the wideband and datalogged with hptuners, the air/fuel ratio going lean at a half tank or less of fuel. I then filled the tank up and the condition went away. I didn't start noticing this issue until until 550 to 600 rwhp.
My solution has been to either keep the tank above half full on the gauge when racing or if I'm on a long trip, I don't make WOT pulls until after a stop for fuel.
The other soulution would be to go with an external pump that draws from the lowest rearward portion of the tank. At the point, 3/8 of a tank might be sufficient but a 1/4 of a tank may still be risky.
Old 10-31-2013, 04:43 PM
Apocolipse
Apocolipse's Avatar
Tank half empty or half full
Old 10-31-2013, 05:04 PM
skydiven4fun
skydiven4fun's Avatar
St. Jude Donor '13-'14-'15
Crap man, sorry for sh*t luck! I'd be crying the blues for sure!, good luck finding out what caused it, I know someone mentioned the #7 cylinder is there a reason that people lose this one ? Sorry if that's a stupid question, just curious.
Old 11-01-2013, 03:17 AM
Lloyd Christmas
I'm running crap street tires with a 400 tread rating, so its not like I was tearing the pavement up with all my traction and causing all the fuel to slosh awkwardly.
Old 11-01-2013, 08:20 AM
1320IN9
1320IN9's Avatar
Redeem yourself & trade for a mini bike
Lol
Old 11-01-2013, 09:12 AM
  #33
02402ramair
02402ramair's Avatar
No traction with less load could put you further up in timing table making you run more timing than the ****** fuel could stand.
Hate to here your lose.
Old 11-01-2013, 11:12 AM
  #34
dankhts
dankhts's Avatar
I'm so diasappointed I can't even put it into words. Pity me, brothers.[/QUOTE]
Yes a bit of pity, G/L sorting it out and fixing it, but like a fast guy told me - what doesn't kill us will only make us faster...
Old 11-02-2013, 10:49 AM
  #35
Lloyd Christmas
Interesting theory. Never heard of that happening.
Old 11-02-2013, 11:41 AM
  #36
storxusmc
storxusmc's Avatar
I lost a built forged Audi engine years ago on the dyno on the first pull after the build... on very very low boost... the fuel system couldnt keep up and detonated a hole in cylinder 6 dumping the coolant into the cylinder hydrolocking the motor pushing the rod out the side of the block...
Was a ****** situation... after that i ran a surge tank in the engine bay that holds enough volume of fuel to prevent any fuel issues..
Old 11-02-2013, 12:58 PM
  #37
Apocolipse
Apocolipse's Avatar
Blew a fully built engine breaking it in at the race track. Low boost as well but was a ford engine (do I need to say more? Lol) anyhow made the pistons stick in the bores and toasted it.
It hurts a lot but take it as a lesson and as a hit to the wallet but get up and get er Goin again. Name of the game.
To FML: Think I've got that 7 cylinder model now
Old 11-02-2013, 05:06 PM
  #38
MotleyDrew
MotleyDrew's Avatar
Its stories like this that I hate..sorry bud
Old 11-02-2013, 06:57 PM
  #39
jerrydonner
Cruising
jerrydonner's Avatar
Hope it comes back together for you without too much expense.
Old 11-03-2013, 08:46 PM
  #40
Lloyd Christmas
IDK. If its just the one piston then I basically have to pay to rebuild the entire motor anyway. I just don't have to buy as many parts. But how can I put it back together without knowing what went wrong?
Quick Reply: FML: Think I've got that 7 cylinder model now
