Timing Twister Switched Wire Location Help
Looking for a switched wire under the passenger foot well fuse box. That I can tap into for the timing twister. It needs to power on and off with ignition, but keep a constant power during ignition. I have been told the coil pack pink wire is an option.
Find the 3 wire pigtail that has 1*switched 12vdc lead, 1* 12vdc constant, and 1 ground all terminated to the plug.
