In Defense of Water Injection
Old 12-28-2013, 01:05 PM
  #221
joshtownsend
joshtownsend's Avatar
when was the last time you saw a stroker that wasn't a complete drag car turn anything above 6k or even 6500?? Big Daddy shifts a 7600 and that simply because my blowers already over spinning.. rpms are everything
Old 12-28-2013, 01:45 PM
  #222
stevieturbo
stevieturbo's Avatar
Until my current engine, my previous were 4" stroke, and in no way whatsoever a drag car, and had no issues using 7k on a regular basis.
You'd need to excel yourself to build a LS motor not capable of making power beyond 6k.
Old 12-29-2013, 10:18 PM
  #223
Apocolipse
Apocolipse's Avatar
Received 1,282 Likes on 927 Posts
Stock motor doesn't lol
Shhhh
Old 12-29-2013, 11:11 PM
  #224
SBCGENII
SBCGENII's Avatar
Every stock Ls7?
Old 12-30-2013, 04:59 PM
  #225
p1bz
p1bz's Avatar
LOL....this thread needs to die. Too many theorys................
BTW...my dicks bigger.
Old 12-30-2013, 08:50 PM
  #226
joshtownsend
shhhh if you think 8.5 inches is big.. maybe its in the top 10
Old 01-03-2014, 07:38 AM
  #227
willig72
willig72's Avatar
Originally Posted by DOUG @ ECS
After downloading over 20,000 programs into LS vehicles in just the last 6 years alone, exactly how many on meth cars vrs non is unknown, I'm hearing nothing but straight meth or you have a power loss.
The great thing about this country is you do not have to agree.
Doug is right but the question I have is: If I had a engine tuned to its peak on meth, then removed that system and installed a water only system, then retune to its peak with that system. How much power would you loose? Without question power will be less but how much less?
Old 01-03-2014, 07:41 AM
  #228
willig72
willig72's Avatar
p1bz
CF Senior Member
Garage is empty, add now
My Corvette Photos
You know the reason I wouldn't tell anyone about my big *****? I wouldn't want anyone to know my wife was that big.
Old 01-03-2014, 08:23 AM
  #229
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
My condolences to your boyfriend.
Old 01-03-2014, 10:56 AM
  #230
stevieturbo
it's a very good question, and would make a great test.
But it would require a proper water injection system, where actual flow can be controlled based on needs and demand.
Almost all standalone systems currently available ( with the exception of some of Aquamists ) just dump liquid in based on some other load based variable.
ie boost, rpm, airflow.
That is fine albeit slightly crude up to a point. We dont inject fuel this way, and for optimal WI, water should not be injected in a 1 dimensional manner
Old 01-03-2014, 12:07 PM
  #231
joshtownsend
if you had a high enoguh octane.. like race gas.... zero but your egts would be alot lower with water.. and that makes for a happier motor.
Quick Reply: In Defense of Water Injection
